Thanks Matt, it's fixed!
login issues?
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Re: login issues?
- Has thanked: 2656 times
- Been thanked: 1248 times
Good to hear, BKM.
So that I'm 100% on this, you came to MVS today and you were NOT logged in as Alschertz. You were logged in as MoVolvos. Correct?
- MoVolvos
Yes Matt, when I click the speed dial link it goes directly to the log in page. Use to get Alshertz's page when I opened a new MVS tab after I'm logged in and that's fixed also. Thanks.
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
The date and time are both wrong when the forum page is pulled up. I'm no longer logged in as anyone else, and after I login the date and time show correctly.
Thanks for the info and for hanging in there with this, gnalan.
I'm building up a new server on https://cloud.google.com/ , where MVS is currently, but on a different VM.
I'm aiming for two things: faster pageloads, and ditching Cloudflare. A secondary effect of these goals will be a fix for this problem.
If anyone cares, I'm moving from Apache to nginx https://www.nginx.com/resources/wiki/. The database will remain MySql/Maria DB.
- MoVolvos
Per gnalan, the time is incorrect, on my start up page also. Thanks
"It is currently Fri Dec 18, 2020 11:38 pm"
- gnalan
Just taken before logging in today. Still shows the same.
Excited for the new server! Hopefully it'll run nice and smooth, and not have the issues Cloudflare has been causing. Cloudflare also uses NGINX.
- MoVolvos
Hi Matt,
It did move ahead a bit but stopped again.
"It is currently Mon Dec 28, 2020 5:00 pm"
Hi Matt,
- gnalan
Date and time are still off.
Also, while trying to upload my attachment, I got the above error message. May just be on my end since I'm having some issues with both mobile data and wifi being problematic (extremely slow). Has anyone else received any error messages trying to add file attachments?
