My '03 V70 Base (~180K mikes) is making an odd noise after I turn it off. The noise starts off quite loud, decreases a bit, then continues for 2-3 minutes until it's gone. I've never heard it before and it appears to be coming from underneath the air filter. See link to video below.
Any guesses or ideas of the cause? Thanks for the help!
Video
https://www.dropbox.com/s/wjy7a2jgkcwxu76/V70Noise.mp4
2003 V70mbase Recognize this sound? 31400693 Topic is solved
- Biggertuna
- Year and Model: 2014 S60 T5
- Has thanked: 12 times
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Sounds like a tired vacuum pump. You may have a vacuum leak somewhere, one place to start is the 'switch' right in the center of the video with brown connector. On the switch, it says 'motor' on one side, make sure it's the hose that goes down towards the pump. If that's fine, may try replacing the switch if the cap looks broken - but no guarantee it will quiet the pump. My pump was buzzing because the brake pedal seal to the brake booster was leaking - may search on youtube
- Biggertuna
Checked the 'switch' and upon touch, the cap sprung off so I'll have to replace it. Otherwise, the hoses look ok and are connected in the proper order.
Thanks for the tip. Let's see what happens after I replace the switch.
- Has thanked: 1497 times
- Been thanked: 3809 times
That’s it. If you put a zip tie around the switch before it springs apart you save yourself switchreplacemrnt.
The new one is improved design, I believe, but a zip tie on a junkyard one or used replacement
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Although a switch, I have referred to this as the "jack-in-the-box valve" in the past. Now you know why.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Biggertuna
Swapped out the old switch today with a Volvo replacement (couldn't find OE/OEM/Aftermarket). Noise is gone and brakes aren't as spongey either.
Replacement switch appears to be of better quality as well. Don't think I'll be experiencing the "jack-in-the-box" effect again.
Thanks for the help.
Added model and part number to thread title
The new part is improved design from OEM
https://www.fcpeuro.com/products/volvo- ... o-31400693
- Biggertuna
I ordered this one. I think it's the same part, but different OE numbers.
https://www.fcpeuro.com/products/volvo- ... o-31265825
