So I have a 2006 2.5T AWD with stock downpipe, and I also have in my possession an "R" (at least from what I was told) downpipe that I was planning to swap in... when I was in the vicinity of the downpipe recently, I noticed that I could not discern a difference in diameter visually, so I broke out the digital calipers and measured them both at the turbo end and the catalytic converter end. They appear to measure the same diameter at both ends.
Is there some other difference I'm missing? Am I just bad at measuring? Is this "R" downpipe actually something else? Granted it was a little difficult to work the calipers onto the one that's installed, but I'm pretty confident that these measurements are accurate for both the downpipes I have. Here's what I measured on both:
So... should I just leave the 2.5T downpipe in there, since it appears to be the same as the "R" downpipe... or is what I think is an "R" downpipe actually a 2.5T or something else, i.e. have I been had?
I guess what I'm really asking is, can anyone confirm these measurements on a certified real-deal "R" downpipe?
S60 2.5T downpipe vs. R downpipe (are they the same?)
- justanotherhumanoid
- Year and Model: 2006 S60
- Has thanked: 7 times
- Been thanked: 17 times
2006 S60 2.5T AWD - Build Log
do88 intercooler, all aluminum radiator, XC90 aux transmission cooler, magnefine ATF filter, Snabb intake elbow & throttle body pipes, custom oval exhaust, rebuilt 16T swap, 17x8" team dynamics pro race 1.2 wheels, ipd sway bars, R brake swap, Hilton tune, sunroof shade that slides open when I step on the gas and closes when I stand on the brakes.
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
I also am unable to see any discernible difference between my R & 2.5T downpipes. I’m willing to bet they are the same. Fit-wise, ordering an aftermarket “high flow” DP (catted or catless) is the same 2.5T vs R.
That being said. It’s pretty safe to say there would be no gain from installing a stock R DP.
Edit: I should say that all my original/stock DP’s are removed from my P2’s & have been replaced with catted higher flowing DP’s. Side by side, there is no difference between the 2.5T & R DP.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Has thanked: 311 times
- Been thanked: 817 times
I would be surprised if there was any difference. I can measure the front dimension on my 06 R for you if it can be done from the top - too cold to get under the car right now!
Based on Pete's corroboration, I'd say save yourself the trouble - I'm calling them the same and I won't bother swapping them, unless someone chimes in with some other data. Glad I didn't go to the trouble of swapping them, and saved some work/effort (until turbo-swap time, at which point it's probably coming out anyway...). Thanks all.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
There are 2 part numbers for the 2.5T, 30793720 & 30793721.
See this for WHAT IT FITS https://parts.volvocarslisle.com/p/Volv ... 93721.html
- - Pete -
For what it’s worth, the Mototec downpipe is very nice & has a removable catalytic converter (3-piece DP, nice V-band connections). Snabb & Revolve also make a nice low-cost 1-piece DP. I have found on both R & 2.5T (healthy) engines that with any of these DP’s you will need to run a downstream defouler/O2 spoofer. Maybe not at first, but eventually you will need to install one.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 4141 Views
- 1855 Views
Last post by liquidBlack
- 311 Views
- 4091 Views
Last post by Lowmiles
- 2312 Views
Last post by oragex
