She needs more than a part to be replaced : time, sweat, more than tools. Couldn't you keep it aside 'till spring time ? During this time lapse, may be willyou have a britght idea about how to do.
Burt i understand the link between you and your car.
Each year, my wife reminds me that, for my birthday, the price of the candles costs me so much more than the price of the cake : So what ?
A T5 abscate, a T5...
C'mon
Manov
The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
S60UT
- Year and Model: 2000 V70R
- Been thanked: 4 times
Oh man, sorry to hear about your loss. Since the 99's are so rare, I would let it sit till you have time to fix it or do an engine swap. Im sure in time, you can find a T5 engine from a P80 or P2. I bought my S70 GLT with a blown engine. Swapped in a low mileage T5 from a 01 S60. Had to get the ECU tuned but since you already have a T5 ECU, you should be good to go.
00 S70 GLT SE T5 Swap
00 V70R
99 V70 T5
01 E46 325XI Touring
09 FX35 Clown shoe
16 Jetta GLI
00 V70R
99 V70 T5
09 FX35 Clown shoe
16 Jetta GLI
- RickHaleParker
- Been thanked: 978 times
There are lots of things that can drop a valve.abscate wrote: 09 Jan 2021, 04:31 Here is something I don’t quite get on valve drops. You lose an exhaust valve, presumably. You pull the head, replace the valve, cut seats, new stem seals. Don’t you expect another valve to drop? Or, is refreshing the seats and stems enough to reduce that probability?
It could be as simple as a broken spring. In the case of a broken spring you might get away with just replacing the spring. Which can be done without pulling the head off if you have a air compressor and the seats are good. I suggest you at least pull the cam cover off and try to determine the root cause. A bore scope might give you some clues.
Active
Past
Past
- Has thanked: 2856 times
- Been thanked: 1332 times
This got me right in the feels. Sorry to raise an already philosophical discussion to an even higher level, but I just had to remark that this is an outstanding life metaphor.manovlov wrote: 09 Jan 2021, 09:44 Each year, my wife reminds me that, for my birthday, the price of the candles costs me so much more than the price of the cake...
- Has thanked: 311 times
- Been thanked: 817 times
Actually I had a P80 go this way back in 2011 - broken spring. From years of forum-watch I'll note that it is a rare failure on P80 engines but sure, formally it could be that. I could see the broken spring with just a flashlight after pulling the cam cover, pics and story here viewtopic.php?f=1&t=40633. I opted for swapping the head because I had a reworked one sitting there already.RickHaleParker wrote: 09 Jan 2021, 10:38There are lots of things that can drop a valve.abscate wrote: 09 Jan 2021, 04:31 Here is something I don’t quite get on valve drops. You lose an exhaust valve, presumably. You pull the head, replace the valve, cut seats, new stem seals. Don’t you expect another valve to drop? Or, is refreshing the seats and stems enough to reduce that probability?
I’ll look at my Jan feb March and maybe take this on. I’m fresh off a head rework on the Silver Duchess so my chi is tuned in at least
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
You wouldn't want us to take a poll and vote on this now would you ?
1999 V70 GLT
1999 V70 GLT
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Wow, what a bittersweet day. But she's like a family dog, or almost another child. The memories and stuff. Yes, really just a bunch of metal and glass etc... But YOU have infused her with a soul over all this time. As far as your avid documentation and the craft you have lavished on the car, and helped all of us with, if it were up to us (collectively) she would live on. I hope you get to work it that way, even if it means scrapping a couple of the other hangers on. 1 of how many T5,M56, 99s? As long as the combustion chamber and piston top aren't too damaged, it would be a Karma thing. But I know, it's not my driveway/schedule/plan/business!!! Hope the best for all, 'cuz I can't get to MVS NY to sweep her away!
Current Volvos:
Ok, I confess. I took the new T4 to the transfer station to dump the rest of the demo material
At 3000 rpm it drives well, shaky at low revs
Here she is at cottage and on I88 and my favourite photo opp at mile 68 southbound
- 21 Replies
- 5906 Views
- 1629 Views
- 32 Replies
- 8350 Views
Last post by SoCalV70T5
- 28 Replies
- 5732 Views
- 12 Replies
- 1470 Views
