2007 XC70: Battery drains overnight, high pitch whine under the hood
turbo2007
Year and Model: 2007 xc90
Has thanked: 2 times
Post by turbo2007 »
jimmy57 wrote: 22 Apr 2016, 17:24 Are you sure it is #37? That shows on wiring diagram to be MAF and the injectors only. Injectors buzzing would flood engine, maybe even hydrolock it if you attempt cranking. MAF sensor wouldn't make noise.
1st post. Great forum, has helped immensely over the last year.
I have a 2007 XC70, and this sounds like the same problem I am having.
Battery drains overnight and I can here that high pitch whine under the hood. Its very "soft", ie its not a loud noise, just very high pitched. You can barely hear it really. I was going to take a piece of vacuum hose and put one end in my ear and poke around with the other end to see if I can find the source of the whine, but I thought I'd ask first.
Plan B will be to start pulling fuses. I know there's a draw, but I haven't hooked up the Voltmeter yet.
Thought I'd ask and see if this might be a common problem someone knows off the top of their head.
I don't know if this is important or not, but I have a green light around my cup holder that sometimes stays on all night unless I lock the car.
Gremlins... I guess. No water damage anywhere. The car's pristine really.
I put a new motor in it. Got it for $500. 135K miles.
Any idea what this is?
Reason: This was split from a similar S80 forum thread
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
With the engine on, off or ignition on?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
the computer box cooling fan may cycle on and off after shut down by design.
Its located in front of the power steering reservoir.
Circuitry is switched by grounding the neg wire, its always powered up, an exposed grounded wire could turn things on continuously.
That particular 5amp fuse is in the engine bay.
Brake vac pump also makes a quiet hum.
turbo2007
Post by turbo2007 »
jonesg wrote: 09 Jan 2021, 18:19 the computer box cooling fan may cycle on and off after shut down by design.
oragex wrote: 09 Jan 2021, 16:43 With the engine on, off or ignition on?
Engine/Ignition both off.Key out.
I'll figure it out and post back later. Whatever makes that whine, I suspect is normal. I think my problem is elsewhere. Something is draining the battery.
I unhooked the negative battery cable and put the volt/amp meter in between, it read 4.5 amps. But all the interior lights came on too so.... I don't know how much that draw should be.
Something else I'm going to have to read up on, somehow while I was messing with all this (1 AM, freezing with a flashlight) I set off the siren alarm. But the battery was unhooked lol!. When I put the battery cable back on the siren got louder. You guys all probably knew this stuff already, but I guess the alarm has its own back-up battery(?).
Anyway, I'll figure this out like I said. Will post back if I find something that might help someone down the road.
jonesg
Post by jonesg »
Yeh, theres a small nicad in the alarm module inside the fender liner, passenger side.
Thats probably due for replacement after 13 yrs too. But not the source of the drain.
Interior lights should go out in a few minutes, close the doors .
Maybe run the outsides the hatch.
