Ball Joints, Control Arms, Struts
537playing
Year and Model: 2005 S60
Been thanked: 5 times
Post by 537playing »
I just wanted to share some tips regarding front suspension of your P2 cars.
Two years ago I replaced my items with a lot of after market products thinking that there wasn't any big difference. What a mistake! So this month I'm replaced the strut with quality parts that included Bilstein struts, Lesjofors springs and Lemforder Links and Febi strut Mounts (via FCPeuro). Simple replacement videos on Youtube.
I had purchased parts in the past from various Vendors such as Rockauto, 1Aauto, Partsgeek. Most are cheap Chinese parts that didn't last for long. A waste of money in the long run. Do not buy.
Here is a picture of my two year old Control Arm from Uro. You can see where the control arm was rubbing/hitting up against the subframe causing clunks
I bought old original Control Arms from erievovo.com. Even though they are used, they are still better than these replacement brands. These actually looked as if they were new.
I'm using original Volvo Ball Joints as replacements. A bit costly but definitely worth the cost. The flange on it is thicker than the URO its replacing. The Uro ball joint was also beginning to rip.
I used this trick to help with installation of the ball joint. Put the ball joint in the freezer the night before install. First attempt and the ball joint was 1/3rd seated. Then I use this PVC setup to hit the rest in. Three hits and it was seated. Cost was just $3.50. Its two pieces that's fits perfect over the ball joint
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The Volvo ball joints are usually made by Lemforder
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Good call on the control arms and ball joints, I just went through the same thing as you probably know. It's amazing how great these cars are when they've got the correct parts installed! My aftermarket control arm were doing the same thing after 6 months. Serviceable used OEM parts should last you at least 5 to 10 years.
2003 XC 70 (sold)
Georgeandkira
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Years ago I contacted a well known hose manufacturer. Their name appears on tensioners, water pumps and other items.
I asked about Uro parts; specifically short, molded hoses (by-pass, short heater, etc.)
The rep emailed me, "Don't ever buy anything from Uro". Gospel according to Gates.
Been thanked: 4071 times
Georgeandkira wrote: 28 Jan 2021, 11:14 Years ago I contacted a well known hose manufacturer. Their name appears on tensioners, water pumps and other items.
There are a couple of things to avoid with URO if you want > 6 month life
Air, vacuum, fuel, oil, ATF, brake fluid, coolant, power steering fluid, and wind.
Their blinker fluid hoses don’t seem to leak.
Has thanked: 311 times
Been thanked: 817 times
Also avoid their items made of solid materials, or anything that's been on the the shelf zero days or longer.
