07 XC70 rear window defogger
Has thanked: 312 times
Been thanked: 818 times
Looks like there are four lines "burnt out" across the middle, see pic.
Anyone fixed this before on a P2 wagon, any tips?
Has thanked: 1613 times
Been thanked: 4075 times
I’ve bought a conductive paint that would fill in scratches and restore the function, but it’s been a few years
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
You will also need to find the locations where it's interrupted
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
I have had success with the conductive paint. Just follow the directions and properly prepare and clean the area.
Finished this job today, thanks folks for the input.
I used the Permatex conductive paint product. Found the nicks with a voltmeter while the grid was turned on. Each line had a separate nick, that's why 4 of them were out. Three nicks in a cluster on the driver's side were probably all due to the same piece of lumber or bed frame rail or whatever, then found a solo scratch over on the right side.
It took me two tries to get all of them done right. You need to paint the line wider than the original, to get good adherence to the window. I can live with that. I used masking tape to make the stencil, not the little stickers that came with the kit. And I set a space heater to 65 ˚F and put it inside the wagon to keep the windows lukewarm for a few hours. Methacrylate glues don't like cold temps. Still have a little paint left over after the four repairs, each one 2-3 cm long
Hopefully it will last!
