2.5T AWD - got a bearing sound/ whining noise underneath Topic is solved
greffel
Year and Model: 2003 S60
Has thanked: 11 times
Been thanked: 8 times
Post by greffel »
Hey
Everything is pressed apart and enjoying the cleaning process ultrasonic style :)
New bearings for the pinion should arrive this Friday ...
With good friends and the right tools everything is possible an quite fun.
Last test drive of old bearings and I'm 99% sure this is the bearing sound that I hear.
Used this guide and the only thing I added was a easier way to take the bearing off closest to pinion gear
Polestar 2 - All electric daily driver :shock:
S60 2.5T AWD with a little bit more power :evil:
greffel
Post by greffel »
Just found the source of the sound, a bad bearing race.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
It's always a relief when you actually identify a problem like that!
2003 XC 70 (sold)
greffel
Post by greffel »
Angel gear is now back together :)
A couple of highlights from my afternoon assembly
RTV should now cure for 24h, so maybe it will find its way back in the car tomorrow.
Blacklab467
Great work, I can't wait to get the results back tomorrow! The part I always dread most is reinstalling the propshaft and Allen bolts.
2003 XC 70 (sold)
greffel
Post by greffel »
Best feeling when you get everything sorted. :):):)
So first I fixed this mess, changed the gasket on the oil return from the turbo and the one to the sump.
Then degreased everything.
Then installed the super clean angel gear, looks and feels brand new :)
Then reinstalling the prop shaft and the moment of truth :)
I'm so happy, this feels a lot better then getting another used one. Now I know the status of my angel gear.
Blacklab467
Nicely done! Did you road test it yet?
2003 XC 70 (sold)
greffel
Post by greffel »
Road test done, with AWD mud test :)
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
greffel wrote: 24 Jan 2021, 10:32 Road test done, with AWD mud test :)
Inspiring greffel!
Has thanked: 311 times
Been thanked: 817 times
Fantastic work!
Including good job changing those turbo return line gaskets while the angle gear was out. Even though they weren't leaking on my cars, I wish i had.
