Steve, once you expose its innards, if it looks like you'll need stuff, I'm getting ready to harvest bits from my '98 XC before I scrap the carcass. It suffered catastrophic failure of the timing belt tensioner, but was doing well right up until then. Let me know.
Looks like this might be a good day to sit by the fire, though.
The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Re: The Resurrection of (10/1998 to 01/2021 )Elizabeth 1999 V70T5M56 Cylinder Head Job
- Has thanked: 1500 times
- Been thanked: 3812 times
Where’s your 98? Maybe a Donation for parts if it is 4 hours from me ?foggydogg wrote: ↑27 Jan 2021, 05:36 Steve, once you expose its innards, if it looks like you'll need stuff, I'm getting ready to harvest bits from my '98 XC before I scrap the carcass. It suffered catastrophic failure of the timing belt tensioner, but was doing well right up until then. Let me know.
Deep chill Coming , 4 days of 0-10F plus wind
Really wanted to get head into shop but it was cold and nasty, struggled but got the deed done
And the diagnosis on Number 3
- misha
- Has thanked: 152 times
Well done!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
So what was the winning way to separate exhaust/turbo for removal ? Kind of looks like you removed a couple of studs to get it out.
1999 V70 GLT
1999 V70 GLT
Short version
I had to break the down pipe connection first. It's three M8 13mm hex nuts. I had to Dremel off the bottom one.
Once the firm pipe eased sideways towards the passenger side, the turbo rocked back off the manifold studs.
I also noticed I have blown exhaust on 1 and 5 cylinders.
- foggydogg
Good work, might be just in the nick of time. Weather down here is gonna get snotty, dunno about up north.
Couldn't tell from the pics, how does the top of the piston look ?
Looks ok, I’ll clean up of course.
- Has thanked: 927 times
- Been thanked: 1000 times
+10 Recycled use of Priority mailing box.
