- Has thanked: 1613 times
- Been thanked: 4078 times
It will go to a local machine shop for cleaning amd inspection, and hopefully then rework
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Decided to fix the passenger door check strap that started popping. Found that the problem was that the two spot welds that hold the mounting bracket to the pillar had failed. I pried the bracket back in place and re-welded the spot welds. Then I added an additional piece of steel between the pillar and the nut which is welded to the bracket, so nothing can pivot and put stress on those spot welds. Worked sweet !! Silent door ! Now I'm going to add that piece of steel to the other door check strap before I have problems with it. Removes any ability for the bracket to pivot over time and stress those spot welds.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 317 times
- Been thanked: 531 times
Clicking door checks are the worst... they make such an awful sound.
The answer lies in the full parking lot of Toyhonbarus in the Olive Garden “ please park here while waiting” areaBut does that mean the soul of the car is gone?
Whose got two thumbs and picked up his renuilt spare starter the day before his starter went out?
You've gained a sense of what will fail next!
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
Was that rebuilt locally? If so, who was good?abscate wrote: 30 Jan 2021, 09:14 Whose got two thumbs and picked up his renuilt spare starter the day before his starter went out?
2023 Lexus RZ450e -66k
Xcel off 890/Broadway in Schenectady
$100
100 meters from Hunts Machine shop, doing my cylinder head!
All the local dealers charging $300 for rebuilds use these guys, but won’t tell you that.
$100
Unsuccessfully chased no crank problem on Abbys S70, Evita
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I know how you feel. Im chasing a shudder sensation that may be the torque convertor
