Has thanked: 1611 times
Been thanked: 4075 times
It will go to a local machine shop for cleaning amd inspection, and hopefully then rework
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Decided to fix the passenger door check strap that started popping. Found that the problem was that the two spot welds that hold the mounting bracket to the pillar had failed. I pried the bracket back in place and re-welded the spot welds. Then I added an additional piece of steel between the pillar and the nut which is welded to the bracket, so nothing can pivot and put stress on those spot welds. Worked sweet !! Silent door ! Now I'm going to add that piece of steel to the other door check strap before I have problems with it. Removes any ability for the bracket to pivot over time and stress those spot welds.
1999 V70 GLT
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 317 times
Been thanked: 531 times
Post by bmdubya1198 »
Clicking door checks are the worst... they make such an awful sound.
But does that mean the soul of the car is gone?
The answer lies in the full parking lot of Toyhonbarus in the Olive Garden “ please park here while waiting” area
Whose got two thumbs and picked up his renuilt spare starter the day before his starter went out?
This Guy!!!!!
This Guy!!!!!
bmdubya1198
You've gained a sense of what will fail next!
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
abscate wrote: 30 Jan 2021, 09:14 Whose got two thumbs and picked up his renuilt spare starter the day before his starter went out?
Was that rebuilt locally? If so, who was good?
2023 Lexus RZ450e -66k
Xcel off 890/Broadway in Schenectady
$100
100 meters from Hunts Machine shop, doing my cylinder head!
All the local dealers charging $300 for rebuilds use these guys, but won’t tell you that.
Unsuccessfully chased no crank problem on Abbys S70, Evita
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
abscate wrote: 01 Feb 2021, 05:36 Unsuccessfully chased no crank problem on Abbys S70, Evita
I know how you feel. Im chasing a shudder sensation that may be the torque convertor
