I found an article in NYC where it was 25van hour or 125vfor the day , in USD, so very similar
It might be old age way to escape the cold, buy a station Bays, hire a guy to manage it, and save one for me
Volvo S70 mystery wobble/vibration/rattle
- Has thanked: 1611 times
- Been thanked: 4072 times
- Has thanked: 987 times
- Been thanked: 1078 times
Do you get a frame lift with these rates or is a lift extra cost? Heat and air conditioning as needed?
- Ocelot
- Year and Model: 1998, S70
- Has thanked: 61 times
- Been thanked: 17 times
You get the use almost all of the tools, except the tyre machine and the wheel balance machine (theyre very pricey and he does it for you). You can place the car on a lift which makes a whole lot of jobs that much easier. The garage is fairly warm, around 15/18 degrees (that's in Celsius haha). So around/below room temperature. In the hot summer it isnt a place you wanna hang out (it gets very hot).
'Hij die zonder zonde is, werpe de eerste steen. Ik buk wel'. Simon Carmiggelt
Recent car
'98 Volvo S70 2.5 10V Europa edition (Freya)
'83 Volvo 340 DLS 2.0 redblock (Loki)
Previous owned Volvo's
'96 Volvo 440 Si 1.8
'87 Volvo 340 GL 1.7
'85 Volvo 340 DL 1.4
Recent car
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
+1abscate wrote: 08 Jan 2021, 02:32 If you replaced your calipers, ever, with non-Volvo rebuilts, it is likely that the guide pins are made of cheap pot metal, also called silver cheese.
These rust and then the caliper grabs and overheats.
The OEM Volvo slide pins are about $15 each but won’t do this. There are several write ups on this
viewtopic.php?f=1&t=90075&hilit=Brake+caliper+pin
It is best to keep Volvo pins and bleeder valves - restore and move these to the replacement calipers.
It’s American to wonder why everywhere we go isn’t at 25+- 1 centigrade
We build houses in deserts then wonder why we don’t have water.
xHeart
Once the water knows you have build a house, it will come. -- The Americansabscate wrote: 03 Feb 2021, 12:05 It’s American to wonder why everywhere we go isn’t at 25+- 1 centigrade
