please help p80 woes
Robertmac100029
Year and Model: 1998 s70
Post by Robertmac100029 »
Hey all I have three questions. I put a 2001 t5 engine into a 99 v70 originally a lpt . I have ironed out most of the stuff....
I keep getting the ecm code 530D malfunction indicator lamp (mil) faulty signal
I keep getting the tcu codes 0023/0087 the permanent one is engine speed (RPM) sensor Signal missing
also i am getting df 13 and df 16 DIM can bus h signal too high and can bus signal too low..
any input will help. I have tried changing the transmission speed sensor.
somewhere I read that I need to change both external sensors on transmission and I dont know where the other one is or what it is so please feel free to explain that as well.
pictures attached below.
volvo 1.jpg (21.26 KiB) Viewed 918 times
volvo 2.jpg (21.1 KiB) Viewed 918 times
volvo 3.jpg (16.76 KiB) Viewed 918 times
Has thanked: 1609 times
Been thanked: 4064 times
Put each chassis into the volvowebstore.com engine and pull up part numbers fit each sensor; they need to be the same
Robertmac100029
what do you mean each chassis? thank you for the reply
The parts engine makes you enter your model, year, engine, and body type....or you can PUT in your VIN, then pulls up the specific parts for your car
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Does your check engine light light up in position 2 before you start the car?
S60UT
Year and Model: 2000 V70R
Been thanked: 4 times
Post by S60UT »
I installed a 01 T5 into a 00 S70 LPT.
I didn't have any issues with transmission sensors. Just had to get the ECU tuned for the bigger turbo and injectors. I did see a MIL communication issue in Vida, but i don't have a CEL. Did you get the ECU tuned ? If so, did tuner mess with the torque limiter ?
00 S70 GLT SE T5 Swap
00 V70R
99 V70 T5
01 E46 325XI Touring
09 FX35 Clown shoe
16 Jetta GLI
Robertmac100029
I have not gotten it tuned. who would do it in Utah? also the CEL is on in position 2 as well as the up arrow for the transmission is blinking.
Robertmac100029
the transmission is not from a 99 either..
S60UT
Post by S60UT »
Nobody in Utah. I had it done through Rolling Motors in CT. People recommend VAST tuning also. You need to get it tuned. Makes a big difference. Im boosting to about 15psi. I think its actually faster than my R.
00 V70R
99 V70 T5
09 FX35 Clown shoe
16 Jetta GLI
