While researching my progressively worsening shudder problem, it was suggested to me to try changing the transmission fluid completely. I've done 2 drain and fills over the past year. The fluid always look nice and red on the dipstick. I was hesitant to do the complete exchange for fear of messing something up. I now feel stupid for not doing it sooner. It was surprisingly easy. Despite clean fluid on the dipstick, the fluid that came out was horrid.
So far today the shudder problem still exists. I read 2 posts on sweedspeed that said their shuddering improved over time after the fluid change. I suppose in the mean time I should start planning to pull the torque converter out of my parts car.
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
- ZionXIX
After this mornings transmission fluid exchange, the drive to work was filled with constant shuddering. However the drive home tonight was fantastic. Smooth shifting gears, excellent acceleration and only minor shuddering at idle. The problem still exists but I suppose the new fluid is lubricating things enough to compensate.
S60UT
- Year and Model: 2000 V70R
- Been thanked: 4 times
Hopefully it will even out. But shuddering at idle shouldn't have anything to do with Tranny. That would most likely be motor mounts.
00 S70 GLT SE T5 Swap
00 V70R
99 V70 T5
01 E46 325XI Touring
09 FX35 Clown shoe
16 Jetta GLI
00 V70R
99 V70 T5
09 FX35 Clown shoe
16 Jetta GLI
- ZionXIX
Thats what I thought but the shuddering was occurring at random and then over the course of a week progressed to varying pulses at idle only in gear at all times, then at nearly any speed but especially around 30-40 mph. It feels like hitting several tiny road bumps in rapid succession or even a split second of slipping. A day after I completely changed the fluid, its non existent driving.S60UT wrote: 05 Feb 2021, 11:31 Hopefully it will even out. But shuddering at idle shouldn't have anything to do with Tranny. That would most likely be motor mounts.
- Has thanked: 1611 times
- Been thanked: 4071 times
My guess is the fresh fluid is giving you better pressure at the solenoids which are now holding the clutch packs in better engagement ? Keep those drain and fills going !
- June
- Has thanked: 523 times
- Been thanked: 261 times
Sounds like a bad plug wire. When did you change the cap rotor and wires last? JuneZionXIX wrote: 05 Feb 2021, 12:13Thats what I thought but the shuddering was occurring at random and then over the course of a week progressed to varying pulses at idle only in gear at all times, then at nearly any speed but especially around 30-40 mph. It feels like hitting several tiny road bumps in rapid succession or even a split second of slipping. A day after I completely changed the fluid, its non existent driving.S60UT wrote: 05 Feb 2021, 11:31 Hopefully it will even out. But shuddering at idle shouldn't have anything to do with Tranny. That would most likely be motor mounts.
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- ZionXIX
New cap, rotor and plugs about 3 years agoJune wrote: 06 Feb 2021, 05:23Sounds like a bad plug wire. When did you change the cap rotor and wires last? JuneZionXIX wrote: 05 Feb 2021, 12:13Thats what I thought but the shuddering was occurring at random and then over the course of a week progressed to varying pulses at idle only in gear at all times, then at nearly any speed but especially around 30-40 mph. It feels like hitting several tiny road bumps in rapid succession or even a split second of slipping. A day after I completely changed the fluid, its non existent driving.S60UT wrote: 05 Feb 2021, 11:31 Hopefully it will even out. But shuddering at idle shouldn't have anything to do with Tranny. That would most likely be motor mounts.
- Clemens
- Has thanked: 500 times
- Been thanked: 228 times
June might be right. Try reseating the plug wires, maybe regap the plugs, clean the distributor contact points. I've had shuddering issues with a Bosch distributor and rotor, Volvo plugs and Bourgicord wires after one year. Took everything apart, back together and it ran smooth as silk ever since.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- ZionXIX
Sure, ill check the ignition components but I can't really ignore the fact that the shuddering is 98% improved after the fluid exchange.
- June
A transmission won't shudder at idle, but a misfire or a bad injector definitely can. If a wire is going bad, temperature can be a variable. May only misfire when hot under load. On your way to work perhaps you encountered more traffic under warmer conditions. Also perhaps the transmission is operating with less resistance to the engine thus reducing the load to engine. A bad wire tends to ground during engine load. JuneZionXIX wrote: 06 Feb 2021, 15:49 Sure, ill check the ignition components but I can't really ignore the fact that the shuddering is 98% improved after the fluid exchange.
My Volvo cars owned
1996 960 ordered
1996 960 ordered
