1999 S70 NA AT no start, no crank. Evita! Evita [ bad aftermarket battery cable 9456836] Topic is solved
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Well, at least FCP has that warranty!
Volvo's OE parts may very well be dropping in quality... it seems it's happening to all brands. They're probably cheaping out on purpose to get us to upgrade to a new car. I was just going over my E39, then noticed in my records some dealer parts receipts from 3-4 years ago with a couple oil and CCV hoses that were replaced (of course with genuine BMW parts from the dealer) and they are already leaking again! I thought I had remembered replacing these things, but figured it couldn't be leaking again already. It's unacceptable given the markup on OE parts compared to OEM and aftermarket.
OEM stuff from FCP has been ordered!
Been thanked: 4068 times
I’m a bit disturbed how the cable went from no symptoms to no crank overnight.
Whiskey Tango Foxtrot?
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
bmdubya1198 wrote: 03 Feb 2021, 08:29 Well, at least FCP has that warranty!
I am running into this with a PS reservoir in my S70. This was replaced a year ago and 6k miles with a OEM part from FCP. It's leaking again which is so disappointing. I don't think it's leaking at the seams yet but it leaks at the cap for sure. I could just replace the cap and see if that cures it, but then I have to spend money on that. The FCP warranty is great, but even if I replace the whole thing it's not certain the new part is going to last the way it should.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Keep sending those defective parts back/ getting replacements from FCP. If their quality assurance people are awake, they will notice all the defects and try to get better suppliers.
Or FCP could just drop their lifetime free replacement policy.
bmdubya1198
850 LPT wrote: 04 Feb 2021, 07:54 I am running into this with a PS reservoir in my S70. This was replaced a year ago and 6k miles with a OEM part from FCP. It's leaking again which is so disappointing. I don't think it's leaking at the seams yet but it leaks at the cap for sure. I could just replace the cap and see if that cures it, but then I have to spend money on that. The FCP warranty is great, but even if I replace the whole thing it's not certain the new part is going to last the way it should.
Upgrade to the 2005+ P2 style PS reservoir, it's a must on the '99+ P80s! These reservoirs are so much better, and don't swell up and leak like the older style. I really don't know why Volvo even sells the old style anymore, they're horrible quality.
The new one has as screw-on cap rather than the 1/4 turn cap, so it seals much better. The reservoir is made of heavier plastic, so it doesn't swell up and leak like the old one. All you need to fit it is the reservoir and the suction hose that goes to the PS pump. I recommend junkyard parts since the hose is outrageously priced new.
You can see how clean it stays. Kitty was keeping the engine warm for me.
850 LPT
Post by 850 LPT »
bmdubya1198 wrote: 04 Feb 2021, 10:10
Wow, thank you so much. I learn something new about these cars every day. And you're right, FCP would actually be well advised to discontinue these as they probably have to replace them under their warranty all the time.
bmdubya1198
850 LPT wrote: 04 Feb 2021, 11:03 Wow, thank you so much. I learn something new about these cars every day. And you're right, FCP would actually be well advised to discontinue these as they probably have to replace them under their warranty all the time.
I was SO happy when I first found out about this upgrade. I didn't want to waste money on the original reservoir since they all end up leaking again anyway.
Added part number to solution. I also wrote up a review at FCP recommending Volvo cable over This aftermarket one
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I had similar trouble with the RAMAC version of the battery cable, bought at IPD and also offered at that time by FCP, on my 850 a while back:
Failure: viewtopic.php?f=1&t=61435
Purchase: viewtopic.php?f=1&t=47706
jreed wrote: 19 Feb 2021, 05:46 I had similar trouble with the RAMAC version of the battery cable, bought at IPD and also offered at that time by FCP, on my 850 a while back:
That’s an excellent write up with root cause analysis. I’ll add part number to that one too.
I’m going to source a clamp with the post for the fuse box connection so we don’t have to buy $90 Volvo cables to make this crap work
Again, jreed leads the way.....
viewtopic.php?f=1&t=61747
