As a mod , we have an agreement with Volvo not to host wiring diagrams here but I can send them to you if I find them. You are free to post them here to meat out your thread
'05 V70 2.5T High Beams died completely - looking for tips on wiring/design Topic is solved
- Has thanked: 1611 times
- Been thanked: 4075 times
Both the light switch and the steering wheel module ( dimmer stalk) are CANBUS on the 2005 models, and it’s the first year of fast CANBUS , the one that gets you to great places like Toronto and Montreal faster.
- June
- Has thanked: 523 times
- Been thanked: 261 times
No the dash blue light did not illuminate. High beam system was kaput. A twice leading up to failure the high beams turned on while my car was parked killing the battery. Putting a used switch or cleaning the old is not worth it as a replacement from Volvo isn't expensive. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
timetobakethedonuts
- Year and Model: '14 XC70 T6 '98 S70
- Been thanked: 14 times
Problem has been identified. I broke a piece of plastic when I double pumped the high beam lever. I assumed I had created a current surge that blew out a driver transistor, and I led darryl down that road. After locating the post I linked to above, and seeing your post, it became evident that a failure in the stalk could be the issue. I did not anticipate it could a be a structural failure, not electrical, but as soon as I looked at the white lever with the three contacts, it looked like an ear attached to it was broken off. In fact, the white piece at the left arrow was formally attached to where the right arrow is. When you pull the lever, the arm rotates CCW, and the three contacts move against those on the circuit board.June wrote: 03 Feb 2021, 22:59 Don't rule out the switch. Mine just broke on my 04 last month. So it is possible the switch died. The dealership charged me $220 to replace it. My high beams died as well. June
I appreciate the bandwidth here, and the assistance in coming up with a plan. Replacing the stalk is literally a 10 minute job, and it isn't that expensive.
- stalk.jpg (476.95 KiB) Viewed 1032 times
theravenousbeast
- Year and Model: 1997
Sorry to gravedig this thread but this was the only thread online that I could find with the exact same issue I have.
'06 S60 2.5T AWD, European model. Pulled stalk and high beams crapped out. Dashboard doesn't show blue indicator. No click when pulling stalk.
Does the '06 S60 have a similar design on the inside of the stalk?
theravenousbeast
- 4513 Views
Last post by ggleavitt
- 11 Replies
- 2316 Views
Last post by erikv11
- 1396 Views
Last post by chiefpontiac
- 883 Views
Last post by BEJinFbk
- 13 Replies
- 1810 Views
Last post by wizechatmgr
