Can you open an ear/Oetiker clamp prior to installation?
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
Normally I install clamps like this by sliding them over the object to be clamped.
But I’m wondering if it’s possible to open them prior to installation so they could be wrapped around a part that’s already installed and can’t be slid onto?
I can’t tell from the photo if the teeth and holes on the right would allow this, or if it’s factory preattached and can’t be opened?
Cars I've owned:
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
That exact model does open.
Has thanked: 1609 times
Been thanked: 4065 times
I think when you buy the real deal they can open. The cheap ones won’t.
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
They can and I have done it. Sometimes one has to slightly bend the tab up so it can be opened, then once installed bend it back down. Be careful not to break the tab -metal fatigue.
Has thanked: 311 times
Been thanked: 817 times
Yes.
I always install them on axle boots by opening.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
i did one today this way, i have both the "real" fixed size ones and "cheap" adjustable ones and both allow this...the "cheap" ones are tabs go down for some reason so i just adjust it close to the size needed then bent the tabs so they dont dig into the boot.
The brand Volvo use are the ones that dont open easily.
2001 XC70 factory M58
2002 XC70 auto (parts car)
prwood
Post by prwood »
I received my genuine Volvo clamps in the mail today and confirmed that they do pop open pretty easily. Will plan on installing them later this year when the weather is a bit warmer... zip ties are standing in until then.
Cars I've owned:
