Hello everyone!!
98 V70 XC. B5254T
We have a Cold snap here in montana, -20's and below, before wind-chill.
The V70 started no problem last night. Ran awesome, and smooth.
This morning, it will start and idle; but as soon as you add gas to accelerate..... Nothing.
Popped the hood, the OUTLET hose of the intercooler, including the idle air hose, is flattened, and squished. BUT. The out let of the turbo is still holding it's shape.
I'm stuck. Any ideas?
1998 V70 XC turbo After Cold snap, no power. [blocked frozen intercooler] Topic is solved
- alpha318
- Year and Model: 98 V70 XC C#505073
- Has thanked: 6 times
- Been thanked: 2 times
Those who say, "Money can't buy happiness", obviously never bought a turbo charged car, or paid a pet adoption fee!
- RickHaleParker
- Been thanked: 958 times
Blocked Intercooler weep hole.
Water in the Intercooler phase changed into ice and blocked the air flow. That why the vacuum from the Intake manifold collapsed the hoses. There is enough air leakage to idle but not enough to keep from choking the engine when you open the ETM.
Option #1: Push the car into a heated garage and let it thaw out. Then clean the Intercooler's weep hole and drain the water out. Inspect the Intercooler for cracks.
Option #2: To get through this cold spell run a Air hose directly from the MAF to the ETM, bypassing the Turbo and Intercooler. The car will run Naturally Aspirated. Which it does most of the time anyway. The car will run like it always has except when you step down hard. With this weather you should not be kicking in the Turbo anyway so it does not matter ... for now.
Option #3 Run a hose from the charge pipe directly to the ETM, bypassing just the Intercooler. You will get some boost but not as much as with a Intercooler. The engine may run a little hotter and warm up quicker because there no Intercooler dumping heat from the Turbo. You can deal with the Intercooler later. There will be a drop in performance because the air going into the cylinders is less dense. One positive is hotter air can get you a gain in fuel economy.
- Has thanked: 1502 times
- Been thanked: 3817 times
Nice diagnosis Rick. Good luck surviving that cold spell, bbbrrrrrrrr
- Has thanked: 1843 times
- Been thanked: 1710 times
Also add a radiator blind. This consists of a piece of cardboard zip-tied behind the hood grille. This can be run but no hotter than whatever the equivalent of +10C is. For some reason Volvo never offered the radiator grill cover in North America.
Placing a heater under the car will also help and Rick's suggestions are great. Never heard of the bypass but that is a good idea.
Good Luck.
Good Luck.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
+1 for getting it inside!
Nothing beats a night in a warm garage.
Currently Sunny and -29 ( Not including wind chill...)
- RickHaleParker
We use to do that decades ago with a 50,000 BTUh forced air Kerosene space heater. We fabricated some round ductwork to fit over the end of the space heater, then drop down under the vehicle to dump the heat in the engine compartment. Made short work out of heating a engine that would not start in cold weather like this. Would need to be really careful doing that with today's Tupperware cars.
BJ makes a good point. Maybe as the VW's are water free and possibly not used this time of year, kick one outside under a cover and move the Volvo in for this cold week or so. Cheapest option of all!
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 126 times
Someone should order a pizza, eat the pizza. Place the box in front of the intercooler. Now idle engine for a half hour to an hour. If all goes well, the intercooler will start to thaw.
- BEJinFbk
You had me at Pizza!wizechatmgr wrote: ↑10 Feb 2021, 11:25 Someone should order a pizza, eat the pizza. Place the box in front of the intercooler. Now idle engine for a half hour to an hour. If all goes well, the intercooler will start to thaw.
- alpha318
So, I can't believe this.
The pizza box trick worked!!
Furthermore.
1. How can I prevent this from happening again? I don't see a weep hole anywhere.
2. What's the best way to mount a chunk of cardboard to the front of a car, without it overheating??
Furthermore.
- 54 Replies
- 8047 Views
Last post by cfelberg
- 16 Replies
- 3021 Views
Last post by hammertime
