Postition #3 is abnormal for either sensor.darrylrobert wrote: 14 Feb 2021, 06:57 hows this for weird..i placed the rear sensor back to its normal position 3 with copper washers and i got the "knock code" moved it back to position 2 and no "knock code"??
The front knock sensor is suppose to be on cylinder #2. Mounted with the wires at 3:00.
The rear knock sensor is suppose to be on cylinder #4. Mounted with the wires at 6:00.
Front Knock sensor listens to 1,2,3. Rear listens to 3,4,5.
1,2,3,4,5
Install the new sensors. Tighten by hand.
1. Route the cables on the outside of the starter motor bracket.
2. Align the sensors. The cable from the sensor for cylinder 2 = 3 o'clock and from the sensor for cylinder 4 = 6 o'clock.
3. Tighten the knock sensors (KS) to 20 Nm.
4. Connect the knock sensor (KS) connectors. Check that the wiring is in the correct position..
5. Secure with a tie strap at the starter motor bracket.
