Combustion cylinder Before and after pics
- Been thanked: 4068 times
You blow it out with compressed air and carry on. Engines arent that fragile, unless you have deviated from the path of the righteous.
- Has thanked: 311 times
- Been thanked: 817 times
EXCEPT the head mating surfaces must be completely flat. A bit fragile there (it's Italian!).
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
Here is the before and after pic of cyl 5. I used a product called Threebond my seafoam is yet to arrive and the local parts store said this is what all the mechanics here use. Its also called subaru upper engine cleaner. After just one treatment i can see the piston ring i couldnt see before but the smooth acceleration was the real proof it actually worked. Like others have said its a good idea not to have large chunks coming off at one time, slowly slowly does the trick.
I was looking into "Hydrogen cleaning" however very few mechanics do it here, i emailed one company and they havent replied, lots of videos online showing that its ineffective at cleaning carbon.
2001 XC70 factory M58
2002 XC70 auto (parts car)
- RickHaleParker
- Been thanked: 979 times
Oh that what the HHO scam warped into. I recall debunking the HHO scammers when they was claiming onboard Hydrogen "generation" would improve fuel efficiency. The HHO people are just as bad as Peter Popoff and his "Miracle Spring Water" .darrylrobert wrote: 18 Feb 2021, 05:09 I was looking into "Hydrogen cleaning" however very few mechanics do it here, i emailed one company and they havent replied, lots of videos online showing that its ineffective at cleaning carbon.
Active
Past
Past
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
I recall spraying water into carbs on big outboards while we revved the snot out of them ( 6 cyl/6carbs).
The exhaust water turned grey, that was the carbon washing out.
Steam cleaning works, you know the sign of a blown gasket ?, perfetly clean and shiny piston.
I just don't know how you'd introduce the water with injectors and no carb throat.
SVO LOU
- Year and Model: 04 XC70, 06 V70
- Has thanked: 44 times
- Been thanked: 5 times
Exactly. You usually can tell which cylinder had the head gasket leak because it'll look like it's been steam-cleaned.jonesg wrote: 18 Feb 2021, 12:21 I recall spraying water into carbs on big outboards while we revved the snot out of them ( 6 cyl/6carbs).
On a side-note, over 25 years ago I worked as a tech on the Lincoln/Mercury side of a dealer, the other side of the shop was BMW/Saab. Apparently Saab's also had a tendency to build up gunk in the combustion chamber so what the techs did was disconnect the wiper washer spray hose from the hood and connect it to a vacuum port on the throttle body and drive it and hit the washer spray button to clean out the combustion chamber...I know they swore by it.
01, 02, 04 XC70, 06 V70
Love this hack!SVO LOU wrote: 18 Feb 2021, 17:51 ... disconnect the wiper washer spray hose from the hood and connect it to a vacuum port on the throttle body and drive it and hit the washer spray button to clean out the combustion chamber...I know they swore by it.
Thoughts anyone? I feel like trying it on my beater 850 this spring.
- darrylrobert
its quite risky because the engine might hydraulically lock. Emailed a few mechanics that work on volvos over 20years old that have been driven by old lady's consider removal of the head the only real fix.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
In the mid 70's the place to go for repairs was Acme Auto Repair in Concord CA. They did it all and had all the machines in house to rebuild the entire motor. After bringing the car in for repair I would just go in and hangout and watch the guys Ernie and Rodney do their thing. No exposure to auto repair at the time so everything was interesting.erikv11 wrote: 18 Feb 2021, 17:57Love this hack!SVO LOU wrote: 18 Feb 2021, 17:51 ... disconnect the wiper washer spray hose from the hood and connect it to a vacuum port on the throttle body and drive it and hit the washer spray button to clean out the combustion chamber...I know they swore by it.
One car that was in the shop had this rattling sound and the next thing I hear is the motor being rev'd and water being poured into the carb from a used Prestone coolant bottle. They too use it for carbon buildup.
Yes, this is the whole point of speculation. The question is if water injection by this simple hack is controllable enough to minimize the risk.darrylrobert wrote: 18 Feb 2021, 20:35 its quite risky because the engine might hydraulically lock. ...
Water injection systems are common, presumably they clean up the pistons.
From VS back in the day http://volvospeed.com/vs_forum/topic/35 ... -build-up/
- 2008 Views
Last post by smileyboy
- 13 Replies
- 1893 Views
- 1496 Views
Last post by MoVolvos
- 1568 Views
Last post by 93Regina
- 785 Views
Last post by TheOtherside
