Vibrations on idle
- Has thanked: 311 times
- Been thanked: 817 times
Most common cause of vibration after the top torque mount is the front engine mount, the non-hydraulic one under the crank pulley. Access from the wheel well.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I would concur with that!
2003 XC 70 (sold)
erikv11 wrote: 18 Feb 2021, 09:24 Most common cause of vibration after the top torque mount is the front engine mount, the non-hydraulic one under the crank pulley. Access from the wheel well.
I'll try to get my hands on some working space ASAP. Thanks guys! I was trying to find something suspicious in VIDA but I couldn't to. Pic attached, readings of hot engine.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
change all the coils with new bosch ones, same as volvo but not in the blue box. check the VVT solenoid, these are both common failures.
Google "volvo vvt solenoid symptoms"
2001 XC70 factory M58
2002 XC70 auto (parts car)
- darrylrobert
My top engine mount is very loose, i can hear the rubber clunk when coasting however at idle i can put a glass of water on the engine and get just a ripple.erikv11 wrote: 18 Feb 2021, 09:24 Most common cause of vibration after the top torque mount is the front engine mount, the non-hydraulic one under the crank pulley. Access from the wheel well.
Congratulations!darrylrobert wrote: 18 Feb 2021, 20:48My top engine mount is very loose, i can hear the rubber clunk when coasting however at idle i can put a glass of water on the engine and get just a ripple.erikv11 wrote: 18 Feb 2021, 09:24 Most common cause of vibration after the top torque mount is the front engine mount, the non-hydraulic one under the crank pulley. Access from the wheel well.
Vageloudakis
- Year and Model: S60 2007
- Has thanked: 2 times
Blacklab467 wrote: 15 Feb 2021, 13:25 Subframe bushings made a huge difference on the engine vibrations that came through the steering wheel. I did the engine mounts ( all 5 ) at the same time. My front hydraulic mount was separated almost completely so that may have been the cause. My XC 70 had 280,000 kms when I did it so all those parts were well past their useful life.
I havw the same problem until saw the normal idle is at 650+/- rpms.
adrian22
- Year and Model: s60 2006
I have exactly same problem with my 2006 V70 engine vibrations much more strong that my other Volvo 2006 s60 that engine runs smooth--same engine on both cars--changed spark plugs and all engine mounts but did not help -synthetic 5x30 oils on both cars-Obviously the engine runs rougher for an reason I dont understand--did you found a solution for your car?
adrian22
- 437 Views
Last post by draser
- 1222 Views
Last post by xc90surfer3
- 29 Replies
- 5958 Views
- 19 Replies
- 6267 Views
Last post by shiloh51933
- 3194 Views
Last post by MadeInJapan
