1997 v70 T5 Stutter at WOT on T5
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
Hello dear Volvo people !
My list of Volvo woes keeps getting longer it seems.
The issue:
My V70 T5 developed a stutter at WOT some time ago.
Resetting the ECU removes the stutter until the car is turned off and restarted.
Checking the ECU didn't yield any codes.
About the car:
It's a V70 T5M from 1997 with the Italian B5204T3 (2.0L making 225hp). It's got 250 000 km on it.
Ignition:
Spark plugs are Volvo and 2 years old, so are the spark wires. Distributor and rotor were replaced along with the plugs.
Battery is new, alternator gives around 13.5V when lights/defrost/AC are on.
Injection:
Injectors are original, I replaced the O-rings and the filters to no avail 1 week ago.
Vacuum:
I've checked for vacuum leaks using a good ole' cigar, found 2 which I fixed (got a lung cancer in the process but what wouldn't we do for our cars?)
Intake:
I've got a RIP kit from do88 installed on the car, every air tube/duct/hose has been triple checked by me/my father/my friends/the neighbours/some random stranger who wondered why my hood was open in the street.
Car has been running on E85 without issues for the past 2 years, I haven't reprogrammed the ECU (boooo I know, I just need the money!) so I've been using a piggyback device.
If you have an idea please share it with me!
You can also just send positive thoughts and prayers to prevent me from going into Volvo depression :lol:
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
Have you checked the fuel pressure under load :?:
I had an issue of the engine falling on its face at WOT, it was a bad clamp on the fuel hose between the pump and the carrier inside the tank.
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Fiodor
Post by Fiodor »
Hmm, how would I go about doing that ?
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Get a fuel pressure gauge and connect to the fuel rail end. Rev the throttle manually in the engine bay while watching the gauge to see if it drops.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
Fiodor wrote: 18 Feb 2021, 11:00 ...I've been using a piggyback device.
Have you removed that to test?
How is your battery? What's the age, brand/quality?
Also -> Amazon link
Fiodor
Post by Fiodor »
Battery is brand new, Fulmen 640A and 64 Ah.
I haven't removed the piggyback thingy, once my tank's empty I'll switch to regular gas and remove the piggyback apparatus.
Fiodor
Post by Fiodor »
Piggyback removed, front lambda sensor replaced, new pierburg tcv installed, new Bosch injectors.
Everything is the same as before (lambda and Injectors fixed some stumbling at idle) ie. drove perfectly fine for 15km after resetting the ECU and then the hesitation at WOT came back.
Still haven't checked the fuel pressure but I don't see how that would explain the fact that the engine runs fine when the ECU just got reset.
It's boosting consistently at 0.9 bar without any spikes.
One thing that's been puzzling me is that my fuel trims are stuck at 0% (using torque pro and xanthefin's app 850-OBDII).
Fiodor
Post by Fiodor »
Oh and I'm also back to regular gasoline.
Goupil
Post by Goupil »
Fiodor wrote: 27 Feb 2021, 09:39 One thing that's been puzzling me is that my fuel trims are stuck at 0% (using torque pro and xanthefin's app 850-OBDII).
Sounds like the ECU is sticking to open loop :?:
Maybe a bad O2 sensor ?
Fiodor
Post by Fiodor »
I replaced the front O2 sensor with a bosch universal one yesterday.
Fixed some stumbling at idle but didn't improve the stutter condition.
And monitoring shows that the car stays in closed loop when I'm not pressing down on the gas pedal too hard.
