I have a 4.5" angle grinder and a $8 DeWalt concrete wheel. The going is... slow.
This is about 20 minutes of grinding. It was a flat top cylinder when I started. I'm trying to make a deep cut cup, to make it a planter.
Anyone have any concrete grinding tips?
Forum rules
- Has thanked: 2857 times
- Been thanked: 1332 times
- Has thanked: 987 times
- Been thanked: 1075 times
Wear a good sealing mask. Breathing silicone dust is bad.
It may be better to use carbide tipped drill bits with a hammer drill to get the depth you want. Use about 3/8 bit and use water cooling. Do not let the bit get hot. Make a ring of holes close together but not overlapping- maybe 2 inch diameter. Then use a chisel to break out the rough cylinder. Expect it to take a long time and keep your patience.
Thanks VLN. I'll do that.
I wore an N95, but I'll get a sealed mask. Thanks!
- RickHaleParker
- Been thanked: 979 times
Focus on the journey not the destination and it will be over too soon.
Active
Past
Past
Haha, so true.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I think you could pour/cast a new one with the cup formed quicker than what your doing. And you could make a few of them different heights at that point. Looks like a piece of Sonotube with a bowl in the bottom would do quite nicely.
1999 V70 GLT
1999 V70 GLT
- Sveedy
It looks like it was the drop from a coring job.
1999 V70 GLT
1999 V70 GLT
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Sometimes if you can't win just join. If a little extra height is not an issue. Find or make a round sleeve and pour new concrete to join or surround the bottom piece while forming your ideal shaped upper planter. It will take too long to cut besides not achieving the shape you want.
- MoVolvos
And ear protection if you continue to grind. Will appreciated years down the road!matthew1 wrote: 23 Feb 2021, 09:42 Thanks VLN. I'll do that.
- MoVolvos
MoVolvos wrote: 23 Feb 2021, 22:27 *
*Sveedy wrote: 23 Feb 2021, 14:55 I think you could pour/cast a new one with the cup formed quicker than what your doing. And you could make a few of them different heights at that point. Looks like a piece of Sonotube with a bowl in the bottom would do quite nicely.
Sorry missed that one.
