Anyone have any concrete grinding tips?
Forum rules
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
I have a 4.5" angle grinder and a $8 DeWalt concrete wheel. The going is... slow.
This is about 20 minutes of grinding. It was a flat top cylinder when I started. I'm trying to make a deep cut cup, to make it a planter.
Also -> Amazon link
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Wear a good sealing mask. Breathing silicone dust is bad.
It may be better to use carbide tipped drill bits with a hammer drill to get the depth you want. Use about 3/8 bit and use water cooling. Do not let the bit get hot. Make a ring of holes close together but not overlapping- maybe 2 inch diameter. Then use a chisel to break out the rough cylinder. Expect it to take a long time and keep your patience.
matthew1
Site Admin
Post by matthew1 »
Thanks VLN. I'll do that.
I wore an N95, but I'll get a sealed mask. Thanks!
Also -> Amazon link
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
matthew1 wrote: 22 Feb 2021, 16:26 The going is... slow.
Focus on the journey not the destination and it will be over too soon.
Active
Past
matthew1
Site Admin
Post by matthew1 »
Haha, so true.
Also -> Amazon link
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I think you could pour/cast a new one with the cup formed quicker than what your doing. And you could make a few of them different heights at that point. Looks like a piece of Sonotube with a bowl in the bottom would do quite nicely.
1999 V70 GLT
Sveedy
Post by Sveedy »
It looks like it was the drop from a coring job.
1999 V70 GLT
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Sometimes if you can't win just join. If a little extra height is not an issue. Find or make a round sleeve and pour new concrete to join or surround the bottom piece while forming your ideal shaped upper planter. It will take too long to cut besides not achieving the shape you want.
MoVolvos
Post by MoVolvos »
matthew1 wrote: 23 Feb 2021, 09:42 Thanks VLN. I'll do that.
And ear protection if you continue to grind. Will appreciated years down the road!
MoVolvos
Post by MoVolvos »
MoVolvos wrote: 23 Feb 2021, 22:27 *
Sveedy wrote: 23 Feb 2021, 14:55 I think you could pour/cast a new one with the cup formed quicker than what your doing. And you could make a few of them different heights at that point. Looks like a piece of Sonotube with a bowl in the bottom would do quite nicely.
Sorry missed that one.
