I recently bought a 1994 850 Turbo and noticed shortly after buying it that it has a parasitic battery drain. The car can't sit for more than two or three days before the battery is too low to turn the engine over. From my measurements, I see about a 350mA draw on fuse 15. I have checked usual suspects on fuse 15 (radio, glovebox light, remote locks, vanity lights, courtesy lights, etc) and still haven't been able to figure out what is using so much amperage. In fact, I think the person who owned the car before me went through a similar investigation of phantom power draw since every thing that I have checked has had loose or broken plastic pieces indicating that someone had taken things apart before.
While I'm still trying to find what is causing the drain, I came across something very strange (at least it seems strange to me). I had taken fuse 15 out so no current should have been flowing through the circuit for the central courtesy lights by the rear view mirror. With the car off, and the doors closed (and fuse 15 still out), I measured the voltage coming to the harness on the light fixture. The voltage measured 9.9 volts. I know that line is supposed to always be "hot" since you can turn on the over head lights even when the car is off, but with the fuse removed, it shouldn't be allowing any flow of electricity to happen (every other thing on fuse 15 is not getting power as far as I can tell). When I put the fuse back in, the voltage at that harness jumps back up to the nominal battery voltage as expected(12.8 volts). Does anyone have any idea why I would be able to measure 9.9 volts to the harness with the fuse removed? Could this indicate what is actually causing the power drain?
Any input would be greatly appreciated.
Cheers,
Bryan
94 850 Turbo Parasitic Battery Drain - Very Strange Phenomenon
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
I would pull fuse 15 and then watch the 9.9volts while pulling the other fuses 1 at a time until it goes to 0
- Has thanked: 1611 times
- Been thanked: 4073 times
The overhead lights are a complex circuit with multiple power feeds and pull downs through the 2/76 lock controller. It won’t troubleshoot like a simple 12v supply, switch, load, ground approach.
You can get a sense of this here
viewtopic.php?f=1&t=88623&hilit=2%2F76+lock+controller
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Aftermarket alarm system,aftermarket radio or you simply have a short somewhere in the circuit.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 2210 times
is it a wagon or sedan? I missed it if you said.
Have you removed the glove box light bulb? Check it is not sticking on. Common issue. You can check easily but sticking your phone in the glove box in video mode and seeing if the light stays on when closed.
Reason for the sedan/wagon is that both are prone to cable breaks in the trunk lid wiring where it enters the trunk and goes to the lid, and the wagon where the wires enter the tailgate at the hinge on LH side. Could be getting a short in either. You can also get similar issues in the door harnesses. At least with the door harnesses you can remove each in turn and see if the draw goes away.
budoboy
- Year and Model: 1994 850 Turbo
- Has thanked: 2 times
- Been thanked: 2 times
Thanks for all the replies.
I have a sedan. Sorry I didn't mention it before.
There is definitely a draw on fuse 15, but there also seems to be a draw on fuse 6(central locking system) with the car off.
For my troubleshooting, I have removed the glove box light bulb, overhead light fixture, unplugged the factory radio, and unplugged the remote locks system module. I did some more troubleshooting today by unhooking the front door harnesses but the draw remained. I will see if I can test the trunk soon.
Thanks to abscate for the link to that schematic. I had no idea there were circuits so inbred in the car. I am not an electrical engineer/technician so I don't fully understand the whole schematic. I tried Zionxix's idea but the overhead light voltage didn't change when I removed every other fuse. The only time it did change is when I would open the door latch, then the voltage would drop to 0 on the overhead light circuit. After looking at the schematic, I am not surprised closing the circuit to the door light would do something to the overhead light.
I think maybe one of the larger fuses or relays could be causing part of the issue as well.
I think I need to get a much better multimeter. The cheapo multimeter I have doesn't have the resolution that I would like and could be causing more confusion than clarity.
Regards.
Regards.
- RickHaleParker
- Been thanked: 980 times
It would help if you tell which two electrical points you are measuring across.budoboy wrote: 27 Feb 2021, 18:18 Does anyone have any idea why I would be able to measure 9.9 volts to the harness with the fuse removed?
Active
Past
Past
If you remove the -ve battery cable, and then connect a electrical tester across the negative terminal to the -ve battery connector, you will see the drain. If that is what you are doing, 10mA is a normal condition. On later P80's up to 50mA is ok.
I have a similar drain on my '95 850 (non-turbo). I pulled fuse 5 (30a, blower speed 4) and the drain ceased, but when I re-plugged the fuse, I heard a short whirring sound in the area of the compressor/power steering pump. I only have the 4th speed on my AC because I need a new resistor for speeds 1-3. What causes the whirring?
I also removed fuse 15 (courtesy lights) because the footlight would come on when I hit a bump, or it would have a problem shutting off when I closed the door. On most older cars there was a button in the door jamb that controlled the interior lights, but I can't find any sort of switch or sensor that does the same for the 850.
- 29 Replies
- 7540 Views
- 2072 Views
Last post by RickHaleParker
- 14 Replies
- 1069 Views
- 1004 Views
Last post by chrism
- 11 Replies
- 3237 Views
Last post by marwood82
