The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
S60UT
Year and Model: 2000 V70R
Been thanked: 4 times
Re: The Resurrection of (10/1998 to 01/2021 )Elizabeth 1999 V70T5M56 Cylinder Head Job
Post by S60UT »
Rack jobs are such a PITA, I think that's why I got my R so cheap because the PO realized what a daunting task it was. The most stressful part of my job was reconnecting the hard lines and not cross threading them. I did cross thread one of them a bit. I cut one of the nuts off my parts car and used that to re-tap the thread. I bought a reman SMI OEM rack and it seems a little softer (over assisted) IMO. It might be feeling that way more because of the new squishy snow tires.
00 S70 GLT SE T5 Swap
00 V70R
99 V70 T5
01 E46 325XI Touring
09 FX35 Clown shoe
16 Jetta GLI
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
The end nuts are flare connectors.
Inverted double flair is more common with American and Asian cars.
DIN bubble flare is more common with European cars.
Determine the type and size and you can replace the threaded connector.
Flaring tools to form the end of the hard line are $12.00 - $20.00.
Has thanked: 1505 times
Been thanked: 3818 times
RickHaleParker wrote: 01 Mar 2021, 13:22 The end nuts are flare connectors.
There is probably enough slack to cut the line and reflare it, even if there isn’t , I’ll document the flare and thread on the return line here
The supply line is a flange an oring on my 1999
RickHaleParker
abscate wrote: 01 Mar 2021, 14:02 The supply line is a flange an oring on my 1999
Is it a Inverted double or a bubble?
45° sides is a SAE Inverted double (Left side in picture).
Rounded sides is a bubble (Right in picture) .
There is a 37° Inverted double but it is not used in Automotive.
Well no luck with that alloy line. It’s almost round and not even moving with a vice grip. Maybe cross threaded fro factory?
On the upside, Tasca shipped me my stem seal kit and FCP my valves and I’ll deliver to machine shop today.
Time elapsed , 40 days from turning first bolt
Has thanked: 1850 times
Been thanked: 1710 times
It will be the dis-similar metals issue. You know this issue from the AWD rear sub-frame and salt over the years.
You may have to cut the pipe off and then heat it to try to get the different metals to expand and contract to break the intermetal 'weld' that has happened.
I wish you lots of luck!
The good news is the end can go back to Detroit with the core so I won’t be spending more time on it
Head should be done end of this is week per machine shop
RickHaleParker
scot850 wrote: 02 Mar 2021, 11:14 It will be the dis-similar metals issue. You know this issue from the AWD rear sub-frame and salt over the years.
Aluminum - Steel Galvanic corrosion will dissolve in a strong Alkaline solution.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
abscate wrote: 01 Mar 2021, 17:11
You get credit for weather delays, and in some cultures, it's either tea-time or beer-breaks.
I stared at my rack once, couldn't figure out how to get a line wrench on either fitting without doing exactly what you did. My problem was solved when the motor blew up.
foggydogg wrote: 02 Mar 2021, 21:16
Kally got hers off on car with dropping, I don’t know how the frack she did that. You can just get a crows foot on them but if they freeze up at all , they will round off really quickly
The trick might be to remove the sway bar and two internal hardlines on the rack to get tool clearance, Clarence.
If you are committed to the rack job like me, then waiting until the subframe is dropped makes the access a lot better. Remember to remove all the ps line clamps first. Worst case, Dremel off and replace with junkyard stock.....sigh , another line(s) to harvest
New lines cost about $100 for return, $200 for supply each but are a joy to put on.
Chassis break on lines for RN engines
-1998 supply is 9191271 , return line is ???
1999- Supply is 9485359 , return is 1282852
