850 Lambda sensor
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
Hy Buddies,
Since 2 days, I have a light on my speedometer, the famous "orange triangle": lambda sensor.
Here's my question : have a to replace the 2 sensors or only one ?
Manov
Lambda sensor Regulating probe.jpg (46.1 KiB) Viewed 1177 times
Lambda sensor Diagnostic probe.jpg (37.18 KiB) Viewed 1177 times
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Only broken one I would go as I like be cheap.
Lambda light is not automatically that it is lambda sensor. It's engine check light. Just to make sure here.
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
Have you tried to read the codes ?
A Bluetooth adapter with xanthefin's app works perfectly.
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
manovlov
Post by manovlov »
xanthefin wrote: 10 Mar 2021, 00:16 Only broken one I would go as I like be cheap.
Thanks.
manovlov
Post by manovlov »
Fiodor wrote: 10 Mar 2021, 00:21 Have you tried to read the codes ?
Does someone knows about which one i should watch over ?
Manov
Has thanked: 2199 times
Been thanked: 1852 times
As mentioned it may not be the lambda sensor. The light is as said a generic engine warning light so don't assume it is the lambda sensor. If one fails it is more common of the upstream one (the one closest to the engine).
manovlov
Post by manovlov »
Salut Neil,
Thanks for this explanation. I will check the codes before any work on this machine !
Manov
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
'95 have OBDI diagnostic ports under the hood.
All you need is a piece of paper and a pencil to write down the flash codes.
Just make sure to check A2 port for codes....it is engine diagnostic.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
xanthefin
Post by xanthefin »
Good points about year model. So yeah engine ECU is hard to reach over OBDII with ELM327 on those years as its most likely not Motronic M4.4 or MSA15.7 (Diesel).
I personally got example that 95 model which doesn't have if you mean that diagnostic box under the hood.. but only OBDII port.
So if no diagnostic box then:
Ritual is the same as if you have Motronic M4.3, MFI system (LH-jetronic 3.2 & EZ129K”) - system combination or Fenix 5.2
OBDII port Pin 1 (EZ) and
OBDII port pin 3 is for then Motronic M4.3, LH or Fenix 5.2 ECU
For me Fenix 5.2 it goes to switch per OBDII pin 3 and then when I close switch it goes to ground to give command to Fenix 5.2. Then LED/light has constant plus from OBDII port pin 16 and ground from the ECU Pin from OBDII port (Pin 3 example) and flashes after pressing switch for 1 seconds and release.
But if with diagnostic box then better go with that way on that car to read flash codes.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
One time my Lambda was nearly running out, and luckily the sensor caught it. I found it at Costco in bulk!
