Rusty muffler flange - How to detach it
Phantomphixer
Year and Model: 2007 XC70
Post by Phantomphixer »
Thanks to everyone who took the time to respond. Several different options appear to have worked for others. I did find Dorman 03127 - exhaust stud kit, that looks promising but not metric. As I clean and prep for reassembly, I will settle on a solution for this. I have a lot to do before then; I pulled the exhaust, driveshaft, rear sub-frame assy, to repair a leaky tank. The things we do for love; but anyway, I will post whatever my solution Is to this problem. Thanks again!
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
Phantomphixer wrote: 28 Apr 2020, 05:37 Thanks to everyone who took the time to respond. Several different options appear to have worked for others. I did find Dorman 03127 - exhaust stud kit, that looks promising but not metric. As I clean and prep for reassembly, I will settle on a solution for this. I have a lot to do before then; I pulled the exhaust, driveshaft, rear sub-frame assy, to repair a leaky tank. The things we do for love; but anyway, I will post whatever my solution Is to this problem. Thanks again!
Bumping this old thread. What was the solution ?
04s60 2.4
04xc70 2.5t
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
You may find some information here
Phantomphixer
After much searching, I never did find the proper stud. It frustrated me because it is a simple splined stud. My old 1998 Jeep used a similar stud in its exhaust (unfortunately a different size). I ended up just using nuts and bolts. One thing I did do that I have not seen discussed is use a ball-joint press (the big C-clamp type) to remove the studs from the flange. It took a minute to figure out the set up but worked great. I preferred that to the grinding and drilling option. If you don’t have the tool, it might be available for free rental from your local auto parts store.
