What causes a valve to "burn"?
This topic is in the MVS Volvo Repair Database » What causes a valve to "burn"?
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Being a member of the burned valve club myself, I'm starting to think that we ought to be recommending replacing valve stem seals as preventive maintenance around 175 K miles for the white blocks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
Been thanked: 4068 times
I haven’t figured out a way to borescope these and have a look at the part of the valve you need to see , short of taking off the exhaust manifold.
I have learned the next time I see valve stem seal smoke, I’ll pull the head and do the seals rather than wait fir the droppedvalve. That will also Letme do the job in Spring/ Fall rather than the dreaded Jan/ Feb
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
abscate wrote: 14 Mar 2021, 04:15 I haven’t figured out a way to borescope these and have a look at the part of the valve you need to see , short of taking off the exhaust manifold.
You can get mirror attachments for the Borescope. Lets you see sideways at different angles.
Active
Past
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
If you try the old rope or air pressure method, you may be able to do the valve stem seals in the vehicle... I know I was able to do that successfully on an '85 Cabriolet.
seggs
Year and Model: '09 S60, 04 XC70
Been thanked: 4 times
Post by seggs »
I bought a 2004 XC70 with 78k mi in 2015. Had a burnt valve at 193k in 2021. During that 115k period I owned it, I ran primarily 87 octane. Valve seals were definitely becoming worn at time given the oil consumption was steadily increasing. Approx 1 qt every 2500 mi. It was also really cold when the failure happened…like -10F in case that has any impact.
I did the valve job myself, which, wasnt too horrible. Just take your time do your research. The process allowed me to also do valve seals, cam seals, timing belt, pcv system, hoses and a few other things easily while the head was off. In the end, my compression came back to almost factory specs and the power improvement was very noticeable. Drove it for another 27k before selling it so must have done something right. I relapped the valve seats and they were beautiful. Only the valve was damaged. I mention that because some have mentioned seat damage. Maybe that occurs if driven too long on a dead cylinder. In the end, a new head isn’t always required. I used all the original components except for the burnt valve and valve seals. One note, I highly recommend oem valve seals. They are stupid expensive, but I used (what we’re supposed to be equal) aftermarket seals, and some oil consumption returned by 15k.
My using 87 octane may have caused the problem, but these days, with the cost differential for premium, If you can get 200k before a valve job, It may not be a be bad choice from a financial perspective. Again, it was a pain in the butt, but for about $500 in parts, I got a very refreshed engine.😃
:mrgreen: Seggs
2009 S60 2.5T FWD 155k
2008 S60 2.5T FWD 150k
2004 XC70, 220k(sold)
2005 XC90 2.5T AWD 173k(sold)
2003 S60 (sold)
For Firefox
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
E Showell wrote: 14 Mar 2021, 03:04 Being a member of the burned valve club myself, I'm starting to think that we ought to be recommending replacing valve stem seals as preventive maintenance around 175 K miles for the white blocks.
Lets see if i get there before any my 10 valves burns. I hope i get time and money fit this summer for operation. :oops:
