The Resurrection of Ekaterina 1999 S70 AWD silver 9470674 Topic is solved
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
abscate wrote: 09 Mar 2021, 08:52 It’s going up in the air in a week or two and it will glow cherry red from oxy
The Seventh Mysterty Bolt problem is solved
The bolt is listed under the 'Torque Tube' and is number 13 here
Part number Flange bolt 985061
which Skandix.de tells us is a M12 x 80 mm with self locking thread
What was old is new again. Ford cars from 1930's and early 1940's used a torque tube rigidly attached to the rear axle while the drive shaft turned inside the tube. Later, the torque tube was removed when the open drive shaft and universal joints were used.
Has thanked: 2200 times
Been thanked: 1852 times
Hey abscate. Here is a link to the fuel pipe info I promised you. Any questions you know how to get hold of me!
viewtopic.php?f=1&t=96710&p=569018#p569018
Been thanked: 4065 times
It’s lift day for Ekaterina!!
Hopefully have some good results and pics end of day and perhaps a running car end of tomorrow.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
abscate wrote: 17 Mar 2021, 04:46 It’s lift day for Ekaterina!!
Good luck!
Are you doing the fuel pump and transfer pump while you have the tanks down? Also, were you able to find all the fuel lines, or are you fabricating them?
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
It was a good day yesterday...
Pushed Ekaterina out of the driveway, aired up, put an old battery in to put windows up and open gas flap. My friend Mike came, we dollied up and made the short trip to the lift
Trailered nice at 60,swervy at 70
Passing STS steel, the remnants of a huge steel industry in NY
Settled Ekaterina into the Bay
Popped the 10 mm nuts and did the electricals from the trunk
Removed the snap ring and pushed the fuel filler gaiter into the hatch hole
Up...up...up..up
Removedparking brake cable, quick call to Neil inCalgary to confirm the slightly different config of the AWD. PINS VS HOOK cable attachment.
Blocked Ekaterina up under the rockers to access the axle
Torque rod bolt out.
Burned off exhaust clamp and removed rear exhaust
Fuel and vapour line , removed the plastic tray that covers these.
Unclipped brake line
And the moment of truth came. The avid MVS reader will remember that I’ve gotten 5/7 of the axle carrier bolts loose but the last two wouldn’t yield to the big Green Monster.
I fired up up the oxy and heated the steel frame member up....zap zap zap...still not coming.
Onto the Alunimum sub frame, a bit less heat...zap zap zap .....SUCCESS!,
Both sides worked out...conclusion....it’s bolt to Aluminum corrosion that grabs these bolts
We blocked up the axle onto the frame jack...and......
It’s a mess on top. The fuel lines are all badly rusted , so we will be fabbing all new lines to get her going again.
I told Caitlin it was a real Rube Goldberg fuel system, but she says it isn’t a true RGM unless it has a mouse...hey...wait a minute...
850 LPT
Post by 850 LPT »
Nice job. How long did it take to drop it down?
