Vida CEM swapping
solitaire
Year and Model: v40 2016
Has thanked: 3 times
Been thanked: 6 times
Post by solitaire »
excellent cracker, now with new code P1 work too
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Nice! ;)
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
solitaire wrote: 19 Mar 2021, 11:57 excellent cracker, now with new code P1 work too
Neat package! What is that CAN BUS Transceiver board you used?
Welcome to MVS.
Active
Past
solitaire
Post by solitaire »
RickHaleParker wrote: 19 Mar 2021, 12:47
Welcome to MVS.
"home made" :D
RickHaleParker
solitaire wrote: 20 Mar 2021, 04:32 "home made" :D
Are you going to contribute a Gerber file to the project?
What chips did you use?
Looks like you are drawing power from Vusb. In the current schematic that is listed as an unknown. Can you confirm Vusb has significant power to run the assembly?
Active
Past
solitaire
Post by solitaire »
RickHaleParker wrote: 20 Mar 2021, 12:13 Are you going to contribute a Gerber file to the project?
for CAN I use max3051 (3.3V), powered direct from teensy (max 250mA), https://www.pjrc.com/teensy/card10a_rev2_web.pdf
max3051 maximum current 70mA x 2 = 140mA (https://datasheets.maximintegrated.com/ ... AX3051.pdf)
gerber and box for 3D attached
gerber_teensy__4.rar
(3.33 KiB) Downloaded 328 times
korpusas.rar
(3.89 KiB) Downloaded 302 times
RickHaleParker
solitaire wrote: 21 Mar 2021, 09:33
USB 5V 500ma is standard.
Teensy 4.0 current is ~100ma.
~100ma + 140MA = ~250ma.
~ 50% of the minimum standard.
No risk of overloading the USB port or coming up short on power.
Active
Past
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Is this intended for swapping CEM modules with used ones without dealer involvement?
vtl
Post by vtl »
ZionXIX wrote: 21 Mar 2021, 14:32 Is this intended for swapping CEM modules with used ones without dealer involvement?
A part of that, yes. We miss acloning software that pulls the flash and EEPROM from damaged CEM over CAN and writes it to the donor CEM.
zajcis
Year and Model: 2019 V60, 1997 850
Post by zajcis »
solitaire wrote: 19 Mar 2021, 11:57 IMG_0181.jpg
Would you like to make some functional copies and sell them to a neighbor country prie Mažeikių?
