The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
Has thanked: 1611 times
Been thanked: 4072 times
abscate wrote: 25 Feb 2021, 05:34 “ try clearing the codes and take her up again”
It might be the ECU....
“ We couldn’t hear the noise”
“ They all sound like that from the factory”
“You need a new OXS Sensor and a MAF”
May Asymmetrically Fly
...and its 56F today and sunny!!
Planning on
Getting rack and subframe back in today
Install Hitch on Shaggkira
.... update at 1700 hours
All done!!
A good day yesterday......
If you leave off the last exhaust stud you can easily swing in the water pipe gasket after the head goes on.
Head is on and torqued!
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
abscate wrote: 22 Mar 2021, 02:55 If you leave off the last exhaust stud you can easily swing in the water pipe gasket after the head goes on.
A light smudge of gasket sealer will hold a gasket in place until you get the bolts in. Kind of like having a third hand.
Active
Past
PRO TIP PRO TIP PRO Tip
Completely forgot to docment this.
If you get stuck on the alloy union on the Power steering return hose....
Stop.
remove hose clamp on reservoir.
Snake the return line off with the rack
Deal with the union on the bench.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Good call on that one. It's a lot easier to clamp the return line back onto the reservoir.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Bright, shiny parts going back on, looks like the weather is cooperating, and you have Help too !
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Maybe I missed it, but did you go with new head bolts or the reuse one time route ?
1999 V70 GLT
New Rein head bolts. It’s hard to reuse them when I heard the noises of them coming out
bmdubya1198
They make some nice noises, huh?
White block head bolts are always ridiculously right. They make some great creaking!
