Vida CEM swapping
blasaab
Year and Model: Volvo xc90/V50/144
Been thanked: 3 times
Post by blasaab »
Hi is this working on a s60 L shape cem from 2008?
repair
Year and Model: S60 II 2015
Has thanked: 2 times
Post by repair »
blasaab wrote: 24 Mar 2021, 03:06 Hi is this working on a s60 L shape cem from 2008?
On S60 - yes, but only up to 10 years, with a different CEM design.
Volvo S40, V40, V50, V60, S60, S80, V70, XC60, XC70, XC90, C30, C70 - Р1, Р2, Р3, 1998 - 2016 - language replacement DIM, ICM, PHM.
solitaire
Year and Model: v40 2016
Has thanked: 3 times
Been thanked: 6 times
Post by solitaire »
it's for platform P1/P2,
S60 from 2008 - P3
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
The last MY for P2 S60 was 2009.
solitaire
Post by solitaire »
yes, sorry my mistake, L shape it's P2
solitaire
Post by solitaire »
to vtl
cracker always finds first two correct, on some version 3td is wrong
maybe it's possible modify code:
if cracking PIN code fail, brute force with first two and 3td use next closest candidate
if you understand what I mean.
vtl
Post by vtl »
I sometimes don't see the right byte in the first 25 candidates (out of 100).
blasaab
Post by blasaab »
solitaire wrote: 21 Mar 2021, 09:33
RickHaleParker wrote: 20 Mar 2021, 12:13 Are you going to contribute a Gerber file to the project?
What chips did you use?
Looks like you are drawing power from Vusb. In the current schematic that is listed as an unknown. Can you confirm Vusb has significant power to run the assembly?
for CAN I use max3051 (3.3V), powered direct from teensy (max 250mA), https://www.pjrc.com/teensy/card10a_rev2_web.pdf
max3051 maximum current 70mA x 2 = 140mA (https://datasheets.maximintegrated.com/ ... AX3051.pdf)
gerber and box for 3D attached
I can open the gerber file off pcb but cant insert it on page like https://www.seeedstudio.com/fusion_pcb.html for manufaction?. do you have more info on the other parts on that board. maybe links for software if you want to share that info
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
blasaab wrote: 24 Mar 2021, 13:49 I can open the gerber file off pcb but cant insert it on page like https://www.seeedstudio.com/fusion_pcb.html for manufaction?. do you have more info on the other parts on that board. maybe links for software if you want to share that info
I had to translate the Russian part of the files name to English before I could load and render on one of the websites ... Unrecognised character error.
Active
Past
RickHaleParker
Looking ahead in hope of finalizing my hardware.
Reference: Tennsy 4.0
Q1. Is the K-line going to go on CTX3/CRX3 ( Pads 30 & 31 0n the back ) or CTX4/CRX4 pins 11 & 13?
( I am assuming PJRC misprinted the pinout CTX4/CRX4 as a second set of CTX1/CRX1 for the FlexCAN libary information).
Q2. Third CAN Bus transciver needed for the K-Line?
A1 ____________________
A2 ____________________
Active
Past
