Vida CEM swapping
solitaire
Year and Model: v40 2016
Has thanked: 3 times
Been thanked: 6 times
Post by solitaire »
RickHaleParker wrote: 24 Mar 2021, 14:45 .....Q2. Third CAN Bus transciver needed for the K-Line?......
for k-line you need k-line transceiver, (something like this https://datasheetspdf.com/pdf-file/1425 ... cs/L9637/1)
but then need modify schematic for logical voltage level...
blasaab
Year and Model: Volvo xc90/V50/144
Been thanked: 3 times
Post by blasaab »
i have a new question. i need to extract the bin file from my cem and send to vdash. Volvo S60 2008 p2 L shaped cem i think its Renesas M32C chip.
best or easiest way to do it? at the moment i only have vida dice clone and a Kvaser Leaf usb to can adapter. Br Richard
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Send to them for what? For PIN extraction? We can teach you how to find it yourself in your .bin file :) Taking it out requires opening the CEM and soldering thin wires to PCB near Renesas chip. Do you want to go this way? Otherwise buying Teensy and one or two CAN transceivers is much safer.
blasaab
Post by blasaab »
Hi we have change headlamp from xenon to halogen. According to Volvo specialist its not possible with Vida. Its possible with vdash but the cem is locked and they need bin file or the cem sent over to them.
I have looked att the teensy chip and downloaded the I/O terminal software but you also needed the pin there.
vtl
Post by vtl »
Yes, in this thread we're discussing how to get the PIN over OBD-II. You need less skills in electronics in order to assemble that rather device and have the CEM cracked while it remains in car than to read the flash using a programmer.
https://github.com/vtl/volvo-cem-cracker
blasaab
Post by blasaab »
And you use teensy as programer to. Setting Up teensy chip looks quite easy. Is there a guide for getting source code to teensy like in aurdino soft?
vtl
Post by vtl »
The project utilizes a classic timing attack and recognizes the valid bytes in the sequence. It is not a programmer. You don't have to do read the flash, it will find the pin code as is (for ~90% of CEMs), just plug it into OBD-II port.
blasaab
Post by blasaab »
Thanks will order parts today for teensy. But to change parameter in cem efter you got the pin is it only vdash you can use if you only have a Volvo Dice?
vtl
Post by vtl »
Yes, for VDASH you need a DiCE. And CASH.
repair
Year and Model: S60 II 2015
Has thanked: 2 times
Post by repair »
vtl wrote: 25 Mar 2021, 21:30 Yes, in this thread we're discussing how to get the PIN over OBD-II. You need less skills in electronics in order to assemble that rather device and have the CEM cracked while it remains in car than to read the flash using a programmer.
Using cracker he can get a pin, enter it into I/O Terminal and read and record the flash.
Volvo S40, V40, V50, V60, S60, S80, V70, XC60, XC70, XC90, C30, C70 - Р1, Р2, Р3, 1998 - 2016 - language replacement DIM, ICM, PHM.
