Hi again
the max3051 is not available from my dealer see picture is this transciver the same?
and on resistor there is many options on is it a standard 0,6w?
Vida CEM swapping
- RickHaleParker
- Been thanked: 979 times
Getting there. Need to wait for the coders to decide on K-Line RX & TX pin assignment.
Active
Past
Past
- RickHaleParker
You mean run a jumper from Teensy pin #2 to Teensy pin #23 (CRX1) ?vtl wrote: 26 Mar 2021, 09:34Rick, you also need a wire from CAN-HS RX to Teensy pin 2. This is how the code looks at the signal and identifies latency jitter.
Active
Past
Past
MaxDenisov
- Year and Model: XC90 2010
- Has thanked: 2 times
Today i tried to make changes to configuration of my car using Vdash and PIN( Thanks to Vtl)
Thanks to Vdash team for great support!
PIN is working well for configuration change:
Freedom!
- 2.jpg (26.35 KiB) Viewed 1311 times
- 3.png (10.96 KiB) Viewed 1311 times
- 4.png (10.75 KiB) Viewed 1311 times
- 5.png (5.32 KiB) Viewed 1311 times
- 6.png (14.23 KiB) Viewed 1311 times
- 7.png (14.76 KiB) Viewed 1311 times
- 1.png (23.46 KiB) Viewed 1311 times
- RickHaleParker
It need to be 120Ω. It is a CAN Bus terminating resistor. Specs are 120Ω at each end of the CAN Bus. The other 120Ω is in the CEM.
Power in watts = V²/R = 5V²/120Ω = 25V/120Ω = 0.21 V/Ω = 0.21 Watts. Needs to be 1/4 Watt or higher.
Active
Past
Past
A while since I posted in this thread, but I have been following along. What are folks planning to use the pin for?
The reason why I am asking is because I don't see any use except using Vdash or similar to change the CarConfig? Or is there another usage where you want to change the CEM flash memory?
Myself have been trying to understand how to do the CarConfig change myself (over canbus), but atm I am struggling with writing a SBL to make any adjustments to the flash memory (where carconfig is stored). I have no problems changing the CarConfig by soldering into the MCU and changing the different parameters manually, but it is a tedious and slow process.
I think it would be a great thing for the Volvo community if we could find an easy way for people to make changes to the CarConfig by using the cracking method vtl has developed?
Quattrodag
- Year and Model: 2006, XC90
and what program to install on the computer to read the pinRickHaleParker wrote: 26 Mar 2021, 09:25Getting there. Need to wait for the coders to decide on K-Line RX & TX pin assignment.
- RickHaleParker
https://github.com/vtl/volvo-cem-cracker
Keep in mind this is a work in progress not a finished product. Not all information sources are up to date. Best to go back to the first page of this thread and get up to date as much as you can.
Active
Past
Past
- 9221 Views
Last post by RickHaleParker
- 9137 Views
- 27 Replies
- 28331 Views
Last post by cn90
- 10 Replies
- 10596 Views
Last post by jonesg
- 5733 Views
