Didn't do anything with anything, just one bolt taken out.
2018 bushings should be still good.
How bad is the vibration anyways? These cars are not the smoothest in general.
Vibration at idle and acceleration after hitting a deer
mrjay62
- Year and Model: V70XC 2002
- Been thanked: 3 times
It could of been longer I'm bad with remembering stuff like that I just have to check on the FCP site see when it was ordered.
I may have been before I broke my neck in 2013. Old people. .. smh....
mrjay62
I missed the vibration question .
As for the vibration I barely noticed anything yes the engine always had a little vibration if you put your hand on it but never felt it in the car or on the steering wheel until I hit the deer. I hit it pulled over walk back to check on the deer then looked at the damage which was minimal, broken clips that hold the plastic bumper trim Just under the hood in front of the radiator. When got back in the car started up noticed it immediately.
- Has thanked: 1611 times
- Been thanked: 4072 times
I’ll be traveling more after April 10 or so, can come see you then.
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
I just got caught up on this thread. Did you check the front or rear engine mount? When I changed my mounts I found the front one to be about 75% separated. I noticed a huge difference in the vibration after I changed those mounts. My separated mount was the one between the engine and radiator, sorry if I didn't go back far enough in the thread and you already checked that.
2003 XC 70 (sold)
mrjay62
I checked FCP site I did replace all the mounts I got the Hutchinson kit, all five mounts along with subframe mounts, next a few weeks later new front struts,Springs and heavy duty upper,strut mounts.
All in 2016 August .
I can see and touch the front ,rear large mount to me they look firm, full,clean and no signs cracking. ... that's not say their not worn-out. Just replace the front passenger side mount.
While I had it off in disconnected the upper and trans mount gave it a few revs engine barely moved back and forth.
Maybe they all need to be replaced again I don't know.
For the amount I don't drive it's hard to believe they all wore out...
I'll try the subframe bushings 1st... its easier for me to lay on my back and work than look down into the engine.
Bad bad neck issues.
Thanks
Thanks
- 1006 Views
Last post by oragex
- 24 Replies
- 2506 Views
Last post by TisMe
- 1716 Views
Last post by oragex
- 6058 Views
Last post by Volvogurl89
- 814 Views
Last post by c70_lindsay
