Vibration at idle and acceleration after hitting a deer
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Didn't do anything with anything, just one bolt taken out.
2018 bushings should be still good.
How bad is the vibration anyways? These cars are not the smoothest in general.
mrjay62
Year and Model: V70XC 2002
Been thanked: 3 times
Post by mrjay62 »
It could of been longer I'm bad with remembering stuff like that I just have to check on the FCP site see when it was ordered.
I may have been before I broke my neck in 2013. Old people. .. smh....
mrjay62
Post by mrjay62 »
I missed the vibration question .
As for the vibration I barely noticed anything yes the engine always had a little vibration if you put your hand on it but never felt it in the car or on the steering wheel until I hit the deer. I hit it pulled over walk back to check on the deer then looked at the damage which was minimal, broken clips that hold the plastic bumper trim Just under the hood in front of the radiator. When got back in the car started up noticed it immediately.
vtl
Post by vtl »
Almost sure it is a compromised rubber or shifted something.
mrjay62
Post by mrjay62 »
I'll go with the bushing , I can definitely see the rear subframe bolts no signs that the subframe moved.
Has thanked: 1613 times
Been thanked: 4078 times
I’ll be traveling more after April 10 or so, can come see you then.
mrjay62
Post by mrjay62 »
Ok Abscate. ..
Thanks
mrjay62
Post by mrjay62 »
hi VTL
What size hole saw did you use?
Thanks
Jay
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
I just got caught up on this thread. Did you check the front or rear engine mount? When I changed my mounts I found the front one to be about 75% separated. I noticed a huge difference in the vibration after I changed those mounts. My separated mount was the one between the engine and radiator, sorry if I didn't go back far enough in the thread and you already checked that.
2003 XC 70 (sold)
mrjay62
Post by mrjay62 »
I checked FCP site I did replace all the mounts I got the Hutchinson kit, all five mounts along with subframe mounts, next a few weeks later new front struts,Springs and heavy duty upper,strut mounts.
All in 2016 August .
I can see and touch the front ,rear large mount to me they look firm, full,clean and no signs cracking. ... that's not say their not worn-out. Just replace the front passenger side mount.
While I had it off in disconnected the upper and trans mount gave it a few revs engine barely moved back and forth.
Maybe they all need to be replaced again I don't know.
For the amount I don't drive it's hard to believe they all wore out...
I'll try the subframe bushings 1st... its easier for me to lay on my back and work than look down into the engine.
Bad bad neck issues.
Thanks
