C30 transmission drain & fill ?!?
Rvolvos
- Year and Model: 2006 xc70
- Has thanked: 73 times
- Been thanked: 23 times
Remove the torx screw from the cable clip. Than you can remove the wire harness and carefully remove the dipstick. You have to bend it slightly. Best to do this from below with the car on ramps.
Fyi you need to reset the fluid counter with Vida or other scan tools after drain and fill.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
2012 S60T6 95k rip
Mikele82
- Year and Model: XC70 04 + C30 T5 08
- Has thanked: 30 times
- Been thanked: 3 times
why exactly do i need to "Fyi you need to reset the fluid counter with Vida or other scan tools after drain and fill."
plan is to measure exactly what came out and put new in...
what does the counter reset do?
if a must, whats a good cheep vida setup i need to get?
Rvolvos
When I did the drain and fill, it shifted not good for a while . Some mentioned it could damage the transmission, not resetting the fluid counter.
I did not have this problem with our P2 Volvo’s.
This Forum has a section discussing Vida software and dice units.
I can double check if iCarsoft scanner can reset the fluid counter.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2012 S60T6 95k rip
Rvolvos
Resetting the fluid counter lets the tcm know that the transmission fluid has been changed
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2012 S60T6 95k rip
- 1540 Views
Last post by Cees Klumper
- 2067 Views
Last post by polskamafia mjl
- 2867 Views
Last post by Archer
- 10 Replies
- 3873 Views
Last post by Blacklab467
- 19 Replies
- 9455 Views
