The Resurrection of Ekaterina 1999 S70 AWD silver 9470674 Topic is solved
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
abscate wrote: 29 Mar 2021, 17:56 The U hose from Carbon canister to canister shut off on the AWD is NLA but you can make one from a FWD J hose....
K
I have to go back and search for the correct size, but I use a standard silicone hose from Amazon for these. Volvo part is too expensive and prone to failure. Just give it a nice amount of slack and it will bend just fine.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Been thanked: 4065 times
850 LPT wrote: 30 Mar 2021, 08:07
K
Dirk
Do you use fluoro-Silcone hose? Standard Silcone is porous, might be ok for vapour, but I am not sure where liquid fuel ends up in the AWD system.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Do the rear diff oil while you have it down. It likely has never been done before, or hasn't been done often.
wizechatmgr wrote: 31 Mar 2021, 08:23 Do the rear diff oil while you have it down. It likely has never been done before, or hasn't been done often.
Rear diff and angle gear are on the schedule, while standing tall. Someone left me a Mitivac present in my garage, imagine that.
Henceforth this 31 day of March shall be known as
Saint Ekaterina Day
The day she was resurrected and rolled her own again.
3 more hours, but she lives!
I had to skip some stuff but cracked the diff and angle gear drains ( hex 12 ) in the lift so I can evacuate them easily in ground
The USAF supported us by air dropping needed parts from FCP
Has thanked: 2200 times
Been thanked: 1852 times
Excellent work by you and your helper! Smart move loosening the dreaded drains while you had better access. At least you have a vacuum tool to suck the oil out of the rear diff and angle gear.
Great to hear Ekaterina is back up and running under her own steam. What else needs to be done to make roadworthy?
Good luck with the remainder, and boy am I jealous of your delivery system for parts. You must have friends in high places!!
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
Congrats!!!!!!!!!!!!!!!
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Great news that it's back on it's hands and feet, but about that parts delivery thing...
In what I suspect was a bar-bet gone bad, back in '63 a C-130 landed on the USS Forrestal.
People think there is an intense rivalry in the Forces, but in fact the Air Force and. navy have this in common....they both want to be in the Navy.....
foggydogg
Post by foggydogg »
abscate wrote: 02 Apr 2021, 02:08 People think there is an intense rivalry in the Forces, but in fact the Air Force and. navy have this in common....they both want to be in the Navy.....
The aircrew in this instant case were Marines, but to your point, we would always tell Marines that at the top of their paycheck was the phrase "United States Navy" - right before the barfight broke out.
