[2001 V70 2.4T] Occasional coolant reservoir boilover
prwood
Year and Model: 2001 V70 2.4T
Has thanked: 9 times
Been thanked: 22 times
Post by prwood »
Welp, the other shoe has dropped. The tiny coolant hose between the thermostat housing and the banjo bolt on the intake manifold has ruptured and the coolant reservoir went dry.
I believe I have enough left over hose and oetiker clamps from replacing the other end of this coolant line, assuming that the fittings are the same diameter. I think I'll have to remove the upper coolant hose, and also remove the serpentine belt and disconnect/move the power steering pump in order to get access to replace this hose. Hopefully I can do it without needing to remove the banjo bolt.
Cars I've owned:
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
The good news is its not December.
