I am not going to remove the drier. It will be replaced along with the evaporator, later this Spring by Volvo garage.
Thanks,
Ching-Ho Cheng
850 AC Condenser's connector bolt (stripped) removal
- ashlee2319
- Year and Model: 2000 V70 NA
- Has thanked: 3 times
- Been thanked: 2 times
lcc014 wrote: 07 Apr 2021, 19:43 I did the passenger side today and was much easier. I used the right angle attachment in the dremel tool. Just one cut to the bolt head and connector came apart immediately. The O-ring was in much better shape than the driver side.
I will double check the top surface of both connectors and file them if needed. I don't have a vacuum pump, so I will let the Volvo garage to do it along with the evaporator replacement. Thank you for all the help. My 400k miles 850 NA will continue to run...
Thanks,
Ching-Ho Cheng
How was it removing the cut bolt out of the original ac line? I’m in the same place right now and need to dremel mine off.
2000 V70 N/A
1999 V70 GLT - Current project car
- Has thanked: 1611 times
- Been thanked: 4075 times
Which bolt are you working on , Ashlee?
- ashlee2319
The two that hold the ac lines to the condenser, the 6mm ones. Mine are the original
2000 V70 N/A
Clean out the hex with a sharp tool like a dental pick. Let propane heat Play on the bolt for 28 seconds
Put the hex bit into the bolt and bang it with28 hammer raps, light ones.
Now try easing it
You use one of the Irwin extractors on the outside if it strips
Now try easing it
- 12 Replies
- 3456 Views
Last post by wizechatmgr
- 9 Replies
- 2466 Views
Last post by cn90
- 33 Replies
- 6623 Views
Last post by loosenut
- 1377 Views
- 1241 Views
Last post by Ou2mame
