2013A XC90 - Faint clunk while it down shifts Topic is solved
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
I recently replaced the transmission torque mount due to the loud clunk when shifting from P to R or D. The clunk was absent for a short while, but it has now returned. In addition, I can feel and hear it while it downshifts during the drive.
Could it be because I reused the 2 old nuts at he subframe and the torque has failed? Other mounts are failing too?
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 97 times
Been thanked: 4 times
Post by loveMy850 »
Oh my God, I wish someone had an answer for you, as I'm experiencing kind of the same when I go to put my '94' 850 wagon in park I get a clunk, it's scareing the heck out of me, any thoughts of yours would be appreciated. TY
loveMy850
Post by loveMy850 »
Oh my God, I wish someone had an answer for you, as I'm experiencing kind of the same when I go to put my '94' 850 wagon in park I get a clunk, it's not all the time but it seems to be more and more lately. it's scareing the heck out of me, any thoughts of yours would be appreciated. TY and Good Luck...πŸ€
xHeart
Post by xHeart »
I now have Hutchinson version of the upper torque mount upper and lower torque rod; preparing to replace the two this weekend. While assessing the removal of the lower rod from the bracket, the rusty ring around the axle at the bearing mount looked suspicious. Any thoughts on the exposer and layer of rust?
Here is the pix:
xHeart
Post by xHeart »
No Change!
Replacing 3 mounts did not eliminate the clunk; it is loudly present when shifting from P to R or D.
My other experience with clunk was 2001 V70XC drive axle, which broke off during removal.
xHeart
Post by xHeart »
Replacing mounts has tighten the front a little, from viberating clunk to sharp and crispier clunk. The down shift while drive is barely audible.
Suspecting axles, with 155,000 miles on these axles, I'm exploring either to service the axle, boots, etc., not sure if GKN boots are available for these axles, or have it rebuild at Raxles, or just purchases a new GKN or Volvo pair.
Your thoughts?
P.S. I do not enjoy raising XC90 and setting it on jack-stand, but way easier to DIY. 850 and XC70 are friendlier to raise.
