MAf sensor, Bosch NLA Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
So what is the problem with the Bremi's MAF, or more specifically, how do they not work ? I have one that I didn't end up needing, so it's just sitting in its box. I can't see FCP taking it back " just because ", so I figure I'll keep it for testing purposes. But I am curious as to what might be wrong with it vs. the Bosch.
1999 V70 GLT
Been thanked: 4069 times
Sveedy wrote: 11 Apr 2021, 10:37 So what is the problem with the Bremi's MAF, or more specifically, how do they not work ? I have one that I didn't end up needing, so it's just sitting in its box. I can't see FCP taking it back " just because ", so I figure I'll keep it for testing purposes. But I am curious as to what might be wrong with it vs. the Bosch.
Ive sent stuff back, “ not needed” with full refund. Call and see!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
It sends wrong data to ecu.
Just like aftermarket ECT or O2 sensor.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Active
Past
RickHaleParker
erikv11 wrote: 10 Apr 2021, 22:41 For Bosch 0 280 217 107, the sensor-only part number appears to be 781 15 1 A, possibly with 106 appended:
781 15 1 A 106 might be characteristics data. Electronics parts manufacturing is still an artform. One cannot just do a bunch of equations and poof one gets exactly what one wants. Electronics parts are manufactured shotgun style more or less. Then the characteristics are graded into different part number specs. Sometime a electronics manufacture will need to grade even more so then the component manufacturer.
Active
Past
Has thanked: 311 times
Been thanked: 817 times
RickHaleParker wrote: 11 Apr 2021, 15:13
OK understood, they might.
So, back on task; are you inferring/implying that your original suggestion:
RickHaleParker wrote: 10 Apr 2021, 13:09
erikv11 wrote: 10 Apr 2021, 12:31 If you don't mind, could you suggest a Bosch part number(s)?
Remove the sensor from the housing and get the Bosch part number off the sensor. ...
probably won't work after all?
RickHaleParker
erikv11 wrote: 11 Apr 2021, 20:47 probably won't work after all?
It might still with some leg work.
From the data sheet above I discovered these cars use the same sensor.
1997 & 1998 Saab 900 2.0L & 2.3L.
1999 Saab 9-3 SE 2.0L.
There might be more ...
Active
Past
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
viewtopic.php?f=1&t=94464&p=547501&hilit=delphi#p547501
The Delphi MAF probe I tried didn't throw any codes, but seemed slightly unstable at highway speeds. They included the proper security torx bit in the package.
