Is radiator fan remains ON normal after engine is OFF
Owenlim
Year and Model: 1996 850
Has thanked: 2 times
Post by Owenlim »
[background=][font=]
[/font][/background]
Is radiator fan remains ON (3 minutes) normal after engine is OFF
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
At least on my '97 850, I would consider the fan running for 3 minutes after the engine is off to be not normal.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Yeah, we had that issue on my wife's 855. It turned out to be a bad coolant temp sensor.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Not normal on 850 and s,v,c,xc70 up to '99.
It MUST turn OFF as soon as engine is turned off.
This can happen when ECT or it's wiring are bad or if aftermarket ECT is installed.
ONLY Volvo ECT or at least Vernet.
Volvo ECT is made by Valeo,but you can't find it under Valeo part#.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Owenlim
Post by Owenlim »
After new original gearbox oil replaced, the transmission seem haywire, is that advisable to add in oil treatment ? If yes, which brand is most suitable for this Volvo 850 gearbox.
misha
Post by misha »
If you flushed it...you ruined it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
aviator5356
Year and Model: '96 850; '05 XC70
Post by aviator5356 »
I had same problem. It was the fan controller /module attached to radiator. Simple fix in concept, but, tough to get at the small screw. and to seat the module on install. But, it can be done w/ out removing the radiator. Harbor Freight sells a mini/thin screw bit drovwr ratchet, works well. And, You Tube = awesome !
2008 Volvo XC70.
Been thanked: 4065 times
Old thread alert. Unplugging the MAF on DENSO equipped cars seems to invoke the same symptom, fan afterrun.
