Hello , everyone .
Has anyone had luck with installing the subframe bushings using the outer plate and a jack under it and pushing it into place.
Having been able to work on this headache until now..
Thanks
Jay
Vibration at idle and acceleration after hitting a deer
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Check out this threadmrjay62 wrote: 14 Apr 2021, 11:47 Hello , everyone .
Thanks
Jay
viewtopic.php?f=9&t=96106&hilit=subfram ... s&start=10
Blacklab467 shows how to make outer washer work with some standoffs to be able to drive in the bushings. I made a version using wood dowel material and it worked well. I flipped the washer so I could start and use the bolt to press in the bushings, flipping the washer allowed the bolt to be threaded in some when the bushing hadn't been pressed in at all. I would get them pressed in a little using the bolt and if they weren't going in even I used a hammer to adjust and then pressed them in some more using the bolt and adjusted as necessary, did this over and over until the bushing was fully pressed in I was able to install them all using only the bolt to press them in. I did break a couple of the wood dowels and bent the washer some but just made a couple of more standoffs and straightened the washer when I was done.
mrjay62
- Year and Model: V70XC 2002
- Been thanked: 3 times
This is the passenger side front subframe, looks like the subframe skewed,or shifted on this side..
Or the chassis bent. We'll see when I get them all done if I can't center the subframe with the bolt holes....
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
It shifts easily. Once you have all the bushings pressed in, follow the subframe alignment instructions in VIDA. You may even need a piece of tube of appropriate size (OD = ID of bushing, ID = OD of bolt).
- 1001 Views
Last post by oragex
- 24 Replies
- 2445 Views
Last post by TisMe
- 1703 Views
Last post by oragex
- 6046 Views
Last post by Volvogurl89
- 810 Views
Last post by c70_lindsay
