Leak from fuel tank when filling up! Topic is solved
ashleyg82v702001
Year and Model: 2001 v70
Been thanked: 4 times
Post by ashleyg82v702001 »
So the other day I filled up with £ 30 of petrol....
It seemed like £10 worth ended up on the floor running out from underneath the car....
So I went on an investigation
The rubber filler to tank connection hose was shot..
This has got to be the stupidest design in the world as replacement is a nightmare...
ashleyg82v702001
So with the car jacked up as high as I could get it it was dropped on axel stands, off with the offside rear wheel and out with the arch liner to see if I could access from there... NOPE!
underneath it looked bleak. The fuel tank bolts corroded and not looking too smart..
Outwith the back seats... All these options I had read were possible ways to get at the tank pipes... Again NO.
ashleyg82v702001
So we made our own solution...
Well that was a job and a half! I jacked Lucy high as I could..
Options
1. Drop the tank to access the rubber filler tube pipe and the air return rubber pipe.
2. Drill a hole in the floor pan as I've seen on YouTube Robert DIY.
3.drop the subframe. 4.come up with another way which was less hassle and redesigned the whole v70 filler assembly..
My issues...
1.Mounting bolts are shot can't drop tank.
2. Dint want to unnecessarily drill the car to shit.(Robert DIY way)
3. Just fook off I'm not pissin about dropping the subframe.
4. Genius..... Well in my opinion.
Here goes...
Pinged the filler hose retaining clips, removed filler neck rubber securing cap fron the fuel flap hatch.
Then removed the clips and cable ties from around the 3 fuel filler pipes and hacksawed through the pipes past the 90 deg angle (not the rubber breather pipe as that can be left in place.. All pipes come out easily in two pieces.
then with the rubber tank connectors still connected to the pipes. Replace and refit opposite way / order of removal then using rubber pipe connectors from a fish/pond supply shop (1" for filler pipe 15mm for air return pipe) reconnect
and refit to car... Easy peesy..
No dropping tank or subframe or dismantling of the rear suspension to do the job...
pbierre
Year and Model: T6 XC70s: '13 & '15
Been thanked: 12 times
Post by pbierre »
You used a rubber hose connector from a fish pond supply shop? I hate to break the news, but you have use rubber
hose manufactured for gasoline resistance. If you leave that hose in there, it will gradually decompose, and jam up your fuel injectors. If you're lucky, the fuel filter will get jammed up first.
ashleyg82v702001
It temp until I find the right guage of hose to tightly fit the aluminium filling pipe
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
ashleyg82v702001 wrote: 18 Apr 2021, 03:29 It temp until I find the right guage of hose to tightly fit the aluminium filling pipe
Part number 8621541 ? € 15,31 incl. VAT.
Active
Past
ashleyg82v702001
That's the tank end done that
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
This happens not too often but I would advice two things:
1. Do not fill up completely your tank until the pumps clicks off. This fills all the way up the vertical tube going to the tank and puts weight on the rubber section which will crack after a while. As you noticed, it's a big job to replace it, the rear subframe needs dropped
2. When filling at the pump, do not lean (or press down) on the pump nozzle with your body weight - this again pushes on the filler tube and puts stress on this rubber section
ashleyg82v702001
ashleyg82v702001 wrote: 18 Apr 2021, 03:29 It's only temp until I find the right guage of hose to tightly fit the aluminium filling pipe
ashleyg82v702001
ashleyg82v702001 wrote: 15 Apr 2021, 12:07 So we made our own solution...
Options
My issues...
Here goes...
then with the rubber tank connectors still connected to the pipes. Replace and refit opposite way / order of removal then using rubber pipe connectors from a fish/pond supply shop (1. 25" for filler pipe 15mm for air return pipe) reconnect DSC_0055.JPGand refit to car... Easy peesy..
