2003 v70 stalls very often. Parts replaced. Need advise
antoniveb
Year and Model: 2003 V70
Post by antoniveb »
Bought ODB scanner.
Car started very rough.
Codes:
P0113#12
intake air
Temperature sensor 1
Circuit High Bank 1
P0103#12
Mass or Volume Air Flow Sensor A Circuit High
Live Data
MAF (g/s) 103.85
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Unplug MAF, the engine will switch into using AFR tables. If it runs fine, replace the MAF, otherwise look for vacuum leaks.
antoniveb
Post by antoniveb »
It runs with MAF unplugged
Buying this
https://www.autozone.com/engine-managem ... 826_0_4995
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
That maf value is through the roof, assuming it was measured on idle?? The more info you provide the greater the chance is you'll solve this.
BMW 540i 2002
S70 Base 2000
vtl
Post by vtl »
antoniveb wrote: 16 Apr 2021, 16:17 It runs with MAF unplugged
Buying this
No! Go to fcp euro, pick an OEM replacement and buy that (on Amazon, or wherever you like). Volvo ECMs are very picky when it comes to MAF. Bosch ME7 only works with Bosch MAF, one part number fitted to that particular ECU.
antoniveb
Post by antoniveb »
kallekula wrote: 16 Apr 2021, 17:11 That maf value is through the roof, assuming it was measured on idle?? The more info you provide the greater the chance is you'll solve this.
Yes. on idle
antoniveb
Post by antoniveb »
vtl wrote: 16 Apr 2021, 17:12
Buying this
OMG it's $200+
kallekula
Post by kallekula »
Like previous speaker said, buy OEM when it comes to maf.
BMW 540i 2002
S70 Base 2000
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
antoniveb wrote: 16 Apr 2021, 17:33
Buying this
OMG it's $200+
or $10 at the junkyard.
Been thanked: 4069 times
You can fix your car for $200, or $10 plus junkyard trip....
Or just light $87 on fire and still have a broken car.
