matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
foggydogg wrote: 15 Apr 2021, 20:22 Still can't figure out how to capture a pic
Save a photo onto your computer, or post a photo here? Or both?
Also -> Amazon link
Has thanked: 1505 times
Been thanked: 3818 times
foggydogg wrote: 15 Apr 2021, 20:22 '05 XC90 V8 at the auction house in DC
https://www.capitalautoauction.com/inve ... b38349a4e6
Very curious thing going on with the ignition key.
Not bad shape, key is jacked and stuck in ignition
Plan on $400 to fix that. :evil:
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
abscate wrote: 16 Apr 2021, 05:13 Not bad shape, key is jacked and stuck in ignition
My 2005 would get stuck in ignition when I first got it. I pulled the interlock cable toward the column lock and tied it down with a piece of solid aluminum wire. No more key stuck in ignition. The plastic jacket on the interlock cable shrinks as it ages. Basically the same problem as the drive cables in power seats.
The big problem I see is the key transponder is not attached to the key. Not a deal killer IF they have the transponder.
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
matthew1 wrote: 15 Apr 2021, 22:34
For some reason their pics won't compute on my end; Steve may be doing some screenshot VooDoo that also escapes me. Posted a pic from the 444 C/L ad, though.
foggydogg
Post by foggydogg »
'78 Bertone 262-ish
https://charlottesville.craigslist.org/ ... 04846.html
Repowered redblock
foggydogg
Post by foggydogg »
I figured if it could be had cheap, I would put it under the pin oak and play with it at my leisure. Hammered for $1100, plus about $300 in fees - not to mention shipping. At this point my new toys can't be so dear.
foggydogg
Post by foggydogg »
'96 850GLT near DC, big ask but way low miles and looks right clean.
https://washingtondc.craigslist.org/nva ... 64695.html
96 850GLT.jpg (56.95 KiB) Viewed 1047 times
foggydogg
Post by foggydogg »
'67 122, a bit skeptical about the 'S' claim.
https://washingtondc.craigslist.org/nva ... 23088.html
Responsible Citizen has the popular corrrigated oil catch-mat under.
Pretty big number for an auto, and about the paint mismatch ...
67 122 2 door.jpg (58.68 KiB) Viewed 1044 times
Has thanked: 292 times
Been thanked: 765 times
foggydogg wrote: 17 Apr 2021, 14:03 '96 850GLT near DC, big ask but way low miles and looks right clean.
38k is very low miles indeed, "possible the lowest mileage 850 in the USA" to quote the over-used phrase. If all that service was done by the dealer (or by a shop but with the right parts, which is essentially never happens) then it may be worth the big ask. If done with aftermarket then watch out, would just be buying a bundle of upcoming service.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Has thanked: 1850 times
Been thanked: 1712 times
Here are a few interesting possibilities for someone out there:
Never seen a stick version of one of these:
https://www.kijiji.ca/v-cars-trucks/cal ... 1561910888
This C70 has an 'oopsie' that needs fixed:
https://www.kijiji.ca/v-cars-trucks/edm ... 1562069733
Then there is this low mileage late model C70:
https://www.kijiji.ca/v-cars-trucks/edm ... 1562039198
Abscate, do you need another one?:
https://www.kijiji.ca/v-cars-trucks/cal ... 1562042327
S70 AWD 00 year.
