Ps I love this car. Any an all help/tips will be very much appreciated... thank you
Just ran my new(to me) 850 out of gas , now it won’t start!?!
NUTSinTHEwind
- Year and Model: 1996 850
- misha
- Has thanked: 155 times
- Been thanked: 432 times
99.9% you fried in-tank fuel pump since the car ran out of fuel.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- RickHaleParker
- Been thanked: 980 times
Filter may be plugged up again.
Contaminants that settle to the bottom of the tank, can be stirred up and sucked up into the fuel system when the tank is run low. Check the filter again. Then start look for other parts of the fuel system that maybe plugged up.
Active
Past
Past
- Been thanked: 4071 times
You can use a tire pressure pencil gauge to confirm the fuel pressure at the rail. Throw it out when done as it will be full of gas
- misha
It would be almost impossible because of fuel pump screen filter in the tank(first line of defense).RickHaleParker wrote: 17 Apr 2021, 16:35 Filter may be plugged up again.
If something is plugged up in the system after fuel starvation situation...it would be a screen filter in the tank.
I would say that after the fuel pump ran out of fuel...it ran bone dry for a while...and few seconds are enough for that.
It was overheated internally and overheat damaged internals of the pump.
The part where it ran for a while and car was driveable was just a borrowed time for the pump.
The other scenario is plugged up screen filter on the bottom of fuel pump and if that is the case....it can also damage and overheat the fuel pump internals.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
What misha said. Check the fuel pressure (what abscate said) to find out.
- 28 Replies
- 11757 Views
- 2726 Views
Last post by mf70
- 17 Replies
- 4574 Views
Last post by volvolugnut
- 1005 Views
Last post by ems_kws
- 33 Replies
- 3844 Views
Last post by hausmeister
