Going into park trans.
loveMy850
- Year and Model: 1994 850 WAGON
- Has thanked: 97 times
- Been thanked: 4 times
Hi guys....ok here's the deal, when I go to park and attempt to put it in park, sometimes it seems to grab and kinda with a thunk between reverse and park. It doesn't do this all the time but it's scareing the heck out of me. I checked my tranny codes, all's clear. I will have my fluids changed Monday, it needs it, brown ugh... If that's not it well what about the linkage and where do I check for the linkage and adjustment?, or whatever else anyone thinks what the problem is. Thank you....❤
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Check the torque link that attaches the transmission to the subframe. If it's never been replaced, there's a good chance it's rotted out and allowing a lot of movement between gears. As far as the transmission internals go, definitely a good idea to keep the fluid nice and clean. A series of drain + refills with a little mileage in between will slowly change out the fluid and helps avoid issues associated with sudden full fluid flushes.
Torque link looks like this under the car:
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
loveMy850
TY didn't make it to change the fluid but attempting that today. I go to the college and they help me out, something's I'm a little sceptical about going there, but money talks. The instructor is Awesome so it's all good. Thanks again.
loveMy850
Hi again hey look I'm sending a pick but I'm not sure if this is what we're talking about,I did replace one of these bushings didn't quite go in right, a friend retried and it looks like it's dropped, he said I need the one closest to the fire wall replaced do. What am I looking for, I know this is causing my engine to shake, but the one I did put in helped a little, got hurt pretty bad and haven't been able to do my own work for awhile. Thanks hun, anything you can tell me will so much appreciated.going to the school today just have a look see. TY
- Chuck W
- Year and Model: 97 854 T5
- Been thanked: 340 times
The one up front at the engine looks like the rubber is broken.
- Has thanked: 2215 times
- Been thanked: 1853 times
Chuck is probably right but I can't tell from that angle for sure. The long threaded bolt in the picture that runs under the cable is the top torque mount. They do fail. What I can't tell is if the inner part has separated from the outer. Basically you have 2 round pieces of rubber in that bush that should have some rubber sections connecting the 2 parts. If those have cracked and separated then it will cause a clunk as Chuck and your advisor has said.
If you can re-post with a picture taken from the side of the bushing we may be able to confirm.
The 3 most likely mounts to cause this issue are the top torque mount, the lower torque mount which you have replaced and lastly the engine pad mount under the RHS of the engine near the front RHS wheel to frame. A gentle jacking of the motor with a floor jack at that end of the oil pan with a piece of wood between the oil pan and jack will show it that has failed. Best done with the RHS wheel off and the car on a jack stand on that side under the frame.
Good Luck.
Good Luck.
loveMy850
Thanks Baby dolls,, man I feel like such a dunce, it's been awhile and it's not that Volvo's are new to me I've had her 14 yrs. but guess,just guess haha she had been so faithful I hadn't had to learn her for at least 10-11 years, I really should have started knowing her sooner, anyways I just ordered the the torque trans sub frame, God what a dork I've been, the upper stabilizer and the 4 subframe bushings at IPD.,and all under 100 bucks, not too shabby huh. Ok guys please keep tabs on me,may need you next week. TY so much.
